Wheel alignment covers toe-in?
Old Aug 5, 2004 | 06:28 AM
SkoorbMax's Avatar
Is toe in even the right term? I need an alignment on my max when I get the front wheels changed. I know that if you have a wheel pointing straight and the other off to a side, then an alignment would cover that. Will it also cover the case where a wheel is slightly bending in? It's nothing you can see with your eye, but I can see after burning through this set of tires that the inside on my front right is slightly more worn than the outside. THanks
Old Aug 5, 2004 | 06:35 AM
Matt93SE's Avatar
STFU n00b!
that's camber you're talking about.
toe is both wheels being pointed in the same direction front/back.
camber is how much the top of the tire leans in/out compared to the car.
an alignment should cover both of those, assuming the shop does it properly.
BUT.. inside edge tire wear can be cause by either problem.
If you're lowered, you may need to get some camber bolts to help adjust it back into spec- but of course you won't know that until you get it to an alignment shop to check the numbers.
Old Aug 5, 2004 | 06:48 AM
SkoorbMax's Avatar
Oh right, camber I remember playing with in GT3 or some such game Or maybe it was physics class! thx!
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
