Engine swapped - starting issue
Old Aug 28, 2004 | 12:50 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
We already swapped cranshaft pos. sensors, camshaft pos. sensors, new starter - battery has charge - grounds are good.... Fuel is flowing, but I've got no spark from the coils. Any suggestions? I was planning on checking the coolant temp sensor tonight after work... thanks for the help
Old Aug 28, 2004 | 10:07 PM
turbomax97's Avatar
pulled codes from ecu - only got the knock sensor code - any ideas guys? I checked the coolant temp sensor - it's not the reason... i'm really lost here... help!
Old Aug 28, 2004 | 10:54 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
you have no spark at all? or spark in some cylinders?
when you swapped the motor, did you or anyone else touch the timing chain? if your chain is off by even 1 link, it could cause a no spark condition.
Old Aug 29, 2004 | 01:38 AM
turbomax97's Avatar
we didnt touch the timing chain - no spark in all cylinders - there is a slapping noise - not metal on metal, coming from the timing chain area it seems like.... Almost like if the motor has been sitting for some time without being started.... I think that is just because it was in a junkyard for a while.... thx
Old Aug 29, 2004 | 01:47 AM
Turbo95Max's Avatar
the slapping noise should go away once you start the engine and get oil pressure to the tensioner. unless your chain is broken and you hear the chain slapping on stuff? mm that wouldnt be good..maybe the junkyard took apart this motor before?
anyways, Seems like its possible the timing chain is off a link. id prolly check that after ive tried all the easier and more obvious stuff.
btw, coolant sensor wont cause a no spark condition.
Old Aug 29, 2004 | 01:48 AM
flashover's Avatar
crap... just make sure that both crank position cylinder sensors (ie, the one under the oil filter, and the one that sits between the tranny and the bell housing) are connected, bolted and tested.
Then check and make sure the cam position sensor (above the belt tensioner) is tight.
Good luck bud, probably wont help you any, but I wish i checked these before i dug in with my swap a few months ago. Would have saved me time and money. Oh well.
Old Aug 29, 2004 | 01:49 AM
turbomax97's Avatar
cool- i don't think that the chain is broken - it's a very consistent slapping noise - which is why i agree with you in that it's prolly because of not enough oil...
what are all the sensors that contribute to a no spark condition?
Old Aug 29, 2004 | 06:32 AM
Kevlo911's Avatar
Kevlo for President
Did you forget hte spark plugs?
I read for a few people it took over 20cranks for hte engine to finally fire up.
Old Aug 29, 2004 | 06:58 AM
nupe500's Avatar
Jedi Knight
first...are the engines from the same year? and how did you check the fuel flow. I had a similar problem when I did my swap, one of the harnesses did not plug into each other, near the drivers side fender, its the harness that has the fuel pump hooked to it. Green wire with orange stripe....thats the one that powers the pump. What I would do is unhook your fuel hoses, have someone crank the car, see if fuel flows out there. Thats what it sounds like to me...I had the same symptoms....everything lit...wants to crank but no cigar
Old Aug 29, 2004 | 04:10 PM
turbomax97's Avatar
the engines are different years but the harness is the one off the old block, and all soleniods etc. are from the previous motor.
fuel press gauges read sufficient pressure - like i said - there's no spark, fuel is there... anyoone?
Old Aug 30, 2004 | 05:20 AM
Stephen Max's Avatar
If you're getting fuel it has to an electrical problem. (Just to be sure, can you smell fuel if you crank with one plug pulled?)
Engine ground connections are good?
Old Aug 30, 2004 | 06:40 AM
nupe500's Avatar
Jedi Knight
my gauges also were reading well, but it wasn't getting delivered to the engine, which is what I would check...as mentioned above. If you're sure that the fuel is getting from the tank to the motor then forget what I said...not sure what else it could be.
Old Aug 30, 2004 | 09:12 AM
turbomax97's Avatar
i'm sure i'm getting fuel as i mentioned - to clarify - plugs are wet.
Old Aug 30, 2004 | 09:13 AM
turbomax97's Avatar
yeah engine grounds are good
Old Aug 30, 2004 | 12:02 PM
Turbo95Max's Avatar
nobody wants to listen to me but im telling ya....it could be the timing chain....uh oh...
Old Aug 30, 2004 | 01:35 PM
Kevlo911's Avatar
Kevlo for President
Hold each coil up in your hand with hte smark plug in it and try to start and see if it sparks.
Old Sep 1, 2004 | 05:02 PM
turbomax97's Avatar
that obviously wouldnt work because the plug wouldnt be grounded
anyway - there must have been a problem with the harness because i switched the entire harness and it fired up - timing chain noises went away once enough oil got in there.
only problem now is that the car revs to 4k rpm when not in gear/ clutch is in - seems to be that the throttle cable is stuck :-/
homewrecker
Aug 24, 2015 08:56 PM
maxinout93
Aug 20, 2015 02:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Blackwind
Aug 5, 2015 06:35 PM
