A/C compressor clutch help??
Old Aug 28, 2004 | 12:53 PM
jamiebooth's Avatar
anyone change their clutch on their A/C compressor before???
did you do it or have a shop do it??
why did u replace it?? was the A/C compressor making a really loud whining noise while your car was idling??
if i have a shop discharge my A/C system is the clutch hard to replace???
Old Aug 30, 2004 | 02:54 PM
MAX2000JP's Avatar
I am having the same problem with mine. I sprayed some lithium grease into it and it quieted down a bit. I believe you can just replace the clutch pulley, which is more than 300 dollars IIRC.
Old Sep 2, 2004 | 04:45 PM
jamiebooth's Avatar
i called nissan and got some prices. $351 for the A/C compressor clutch and $349 for just the A/C compressor (comes with the clutch). the A/C compressor is cheaper than just the clutch.
Old Sep 3, 2004 | 09:32 AM
Maximus_95's Avatar
I just got mine replaced for a used one. cost me 350 bucks total.
and yes, it did make a loud noise from the passeger side. got scared for a little bit.
get it replaced, if you dont, your belt may shred and it will be more expensive to replace. its only louder because when your A/C compressor goes out, all the other clutches are working harder to keep it running. fix asap.
Old Sep 3, 2004 | 09:53 AM
Matt93SE's Avatar
STFU n00b!
pick up a clutch assembly from a parts store or something. many places can get them other than the dealer and they're much much less.
either that or pick up a used compressor at the junkyard. If you get a year of use out of it for $50, IMO it's worth it instead of bending over for an OEM unit.
user 11122324
42
Jul 18, 2022 03:35 PM
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
