NGK price?
'bout average. If you are doing them yourself, get coppers (NGK BKR5E-11) for about $10 for all 6. You have to do them twice as often (30k rather than 60k), but it's not that hard.
Just realized you have a 5th gen. It probably won't make a difference since the only difference pretty much is the VI, but get some input from another 5th gen owner to make sure.
Because they cost 1/6 as much. If you really hate changing plugs that much or are having it done then plats are worth is, but I really don't mind doing it so I can live with changing them twice as often.
Thanks, I haven't changed the plugs in the max yet but I usually get plats for my other cars but they were like $2 each not $10.
They do have the iridium on ebay for like $40 a set. I would get these before the plats but may just go copper for now. thanks all!
30k instead of 60k ... sure its half the life, but thats between 2 to 3 years of driving. it's not like you're changing the plugs every 6 months.
are you so lazy that instead of having a better sparking, better conductive plug that you only want to change your plugs every 6 years?
my .02c
my .02c
Originally Posted by flthere
may i know where to buy coppers please ... thx
I personally run NGK coppers for these reasons:
-1.50 a piece versus the 10.00 per platinum plug (advanced auto parts)
-better spark (copper inherently conducts better then platinum)
-It takes me less then a hour to change 6 plugs
In regards to using iridium spark plugs, the dyno results I've seen on a VQ30DE engine provided no gains.
If you do want to get platinums, I'd suggest contacting Jerry Rome Nissan or Courtesy Nissan. Both companies provide discounts for maxima.org members.
Originally Posted by yamehoo
Stay away from them, they're not for our car.
Info from http://www.ngksparkplugs.com:
1995 NISSAN MAXIMA GLE 3.0 V6 VQ30DE FI DOHC
Spark Plug Part No. Stock No. Plug Gap Photo
Standard BKR5ES-11 2382 .044
V-Power BKR5E-11 6953 .044
G-Power Platinum BKR5EGP 7090 .044
Laser Platinum PFR5G-11 * # 2647 .044
OE Laser Iridium IFR5E11 ^ 7994 .044
Iridium IX BKR5EIX-11 5464 .044
* Premium Laser Plug # Original Equipment
Copper is a soft metal and has a low melting temperature. That's why copper plugs don't last long and why the electrode is so damn big on a copper spark plug.
Assuming 100k miles of driving....let's say you change your copper plugs 4 times.
4 x 6 x $1.50 = $36
The average wage in this country is $17/hr. It takes you 3 hours to change the plugs 4 times. $17*3 = $51
So, copper plugs cost you $87 for 100k miles of driving.
For plats, you change it once....
$10*6 = $60
takes 45 min to install them, so $12.75 for your labor.
Plat cost: $72.75.
http://www.babcox.com/editorial/cm/cm120032.htm
This is a really good article about spark plugs.
The VQ is designed to run plats, and in the long run they're cheaper. Just use plats or idridium.
KabirUTA13
19
10-17-2015 03:15 AM
