Interesting HID chart...
Old Sep 23, 2004 | 10:40 PM
Rowan's Avatar
Interesting chart I found for those looking into retrofitting HID projectors...
http://faq.auto.light.tripod.com/car-oem-hid.htm
sorry if it is a repost!
Old Sep 24, 2004 | 10:29 PM
deezo's Avatar
Nice find!
Old Sep 24, 2004 | 10:37 PM
† ErV †
Reality check list; for 1500$ i have:
noticeable hotspots.. yep
colour variations across the beam.. yep
lower output.. yep
As far as the output goes it's a compromise between range and brightness. I have mine slightly dipped and output is great, but range leaves something to be desired. it would also appear my left hl produces about 3 feet shorter beam than the right.
Old Sep 25, 2004 | 02:19 AM
Rowan's Avatar
umm right...
what is your set up evil? and why do you say, " lower output.. yep" then say, "output is great" 1 line later?
I have Z-max 7000k which has less lumens than 4100k HID's and I still have unbelievable output, no color variations that I can see, and my range is insane! I can't wait to do a projector retrofit to focus the beam. My only complaint is simply that I used to blind people before I lowered them...
So that chart is a guide to the best projectors set up.
Thanks Deezo. Hopefully, people will start doing more retrofits themselves and the HOW2 will become common knowledge.
Old Sep 25, 2004 | 10:16 AM
† ErV †
Originally Posted by Rowan
umm right...
Did you even read my post? Output on stock aim is poor. To increase it, you need to dip the light down, which lowers your range.
Old Sep 25, 2004 | 10:43 AM
BlueC's Avatar
wat
How exactly does that INCREASE the output??
This doesnt help in any way of explaining your first post.
Anyways, for $400, I have 5x the amount of light. I have little or no glare coming from my headlight, and it looks damn sexy.
Old Sep 25, 2004 | 11:36 AM
Rowan's Avatar
Agreed BlueC. Your projectors are sick. Where are your pics of the beam patterns? Maybe that will convince evil roads victim.
Old Sep 25, 2004 | 12:04 PM
† ErV †
you are focusing the output in a smaller area since the beam is shooting with more of a downward angle. It does not increase the actual lumens, it makes it appear brighter on the ground.
When you get the lights, then come back and tell me not so. Meanwhile, enjoy your illegal kits and projectors (which i will eventually do since that's the only way to get a great focus, spread and output).
beyond
Old Sep 25, 2004 | 09:30 PM
BlueC's Avatar
wat
Explain your "$1500" setup. Thats where im confused. Projectors, yes technically illegal when retrofitted, produce more useable light. I think they are perfectly fine, they dont give the glare alot of other cars do. Not to mention, it reflects extremly well on road markings (when using HID projectors), so you dont even need to aim them that high.
Old Sep 25, 2004 | 11:34 PM
† ErV †
I was talking about his kit. Yes, yours is illegal too but not like i care. Thing is you are both talking about something you have no clue about.
http://www.courtesyparts.com/Merchan...e=2002HID-PAIR
http://www.courtesyparts.com/Merchan...Category_Code=
shipping
trip to local ace for fuses, extra wires, couplers etc.
Old Sep 26, 2004 | 12:18 AM
Rowan's Avatar
It's cheaper if you don't do a retrofit with courtesy parts....
Parts on EBAY or HIDTECH in NYC or Deepak in Montreal and then make it yourself for about 500-700 bucks.
MOST EXPENSIVE way from HIDTECH:
300 custom retrofit labor cost
100 "expert" wiring of bi-xenons
450 for:2 Hella ECE spec D2S projector, 2 Hella generation III ballasts.
2 Philips 85122 D2S HID bulbs (4300K).
50 for plug and play harness
TOTAL: $900
NOTE: IF you do it yourself you're talking $600 and if you use cheaper projectors its less.
Old Sep 26, 2004 | 09:06 AM
† ErV †
I wanted OEM...
Old Sep 26, 2004 | 10:51 PM
jcy98maxse's Avatar
Turbo is too much fun!
honestly one can find everything they need for less than $500, I bought mine $90 for x5 oem projectors, $275 for oem Hella Gen 2 ballast and Phillips 4200k bulb, misc parts $30, my setup cost me less then $400 (more for valeo projectors or bi xenon projectors),
o heres some beam patterns:
Cutoff line:
http://memimage.cardomain.net/member...5_122_full.jpg
Look at where the light hits the wall and how far away that is, our stock headlight will never reach that far...
http://memimage.cardomain.net/member...5_124_full.jpg
Light output on wet roads...
http://memimage.cardomain.net/member...5_127_full.jpg
Old Sep 26, 2004 | 11:07 PM
jcy98maxse's Avatar
I wanted OEM...
OEM is impossible to get when Nissan never made anything like this for our year's maxima, therefore we have to use other companies "oem" parts like BWM, Audi etc... If u really want some "oem" projectors then retrofit some 6th gen projectors in ur car, called them nissan "oem" parts and be happy...
Old Sep 27, 2004 | 09:42 AM
BlueC's Avatar
wat
I wanted OEM...
All of my parts are OEM, not nissan OEM, but they are higher quality imo.
You obviously did it the hard way, for $1500 you really should have look towards projectors. HIDs + Reflectors are really not that great together. There is way to much glare from them. You could have gone through www.hidtech.com and payed them $300 or $400 to do them for you. It would have resulted in a much better beam pattern, no glare, and more money in the pocket.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Vistance
Sep 17, 2015 05:17 AM
