Reinstalled gauge cluster and now odometer doesn't work!
Old Sep 25, 2004 | 06:14 PM
95maxrider's Avatar
Lightly modded
Well, Patrick and I finally finished up the gauge cluster, but upon driving home I realized that neither the odometer or the trip odo. works. The cluster worked perfectly yesterday, but today we put in two red 194's and fixed some wiring that crossed the dimmer. We didn't go into the cluster besides the bulb change. Patrick and I were wondering if the odo is on the same circuit as the speedometer, because the speedo still works fine. Patrick said he will come into the thread soon and go into greater detail as to exactly what he did. Post away....
Old Sep 27, 2004 | 04:50 PM
95maxrider's Avatar
Lightly modded
UPDATE- Odometer works, but sporadically. It works for a little...then stops...then works again. I'm guessing it's a loose connection. Also, the speedo needle acts like it's sticking. It basically jumps when accelerating and isn't smooth. What would be causing this? The LED needles were installed by Import Intelligence, so I doubt they were installed incorrectly......
Old Sep 28, 2004 | 09:08 AM
phenryiv1's Avatar
Mod her. Ate her.
Call II about the needle issue- they may try to tell you that it was an F-ed up gauge to begin with . I can look it over one weekend, but not this coming weekend.
Old Sep 29, 2004 | 07:56 AM
phenryiv1's Avatar
Mod her. Ate her.
Nick- any update? Tell me this- does the odo failure correlate to the times when the speedo does not work?
Old Sep 29, 2004 | 10:34 AM
95maxrider's Avatar
Lightly modded
To be honest, I can't remember if they correlate, but it very well may. It all was working fine yesterday...so who knows what's going on.
Old Sep 29, 2004 | 10:35 AM
phenryiv1's Avatar
Mod her. Ate her.
Crazy...We need to come to terms on the Cefiros.
I am about to order my new clutch- 4th Gen OEM with a 5th Gen Pressure Plate.
Old Sep 29, 2004 | 10:38 AM
95maxrider's Avatar
Lightly modded
Hey man, you tell me what you want to pay, and it's cool with me.
Why the 5th gen PP? How much does a real OEM clutch cost? Where are you getting it from?
Old Sep 29, 2004 | 10:42 AM
phenryiv1's Avatar
Mod her. Ate her.
Dave B the parts guy. The 5th gen PP because it is thicker and can handle abotu 50 more HP than the 4th gen, but it actually costs less. the specs and a fit-test show that it should match up. I am ordering the 4th and 5th gen PPs, and will return the one that does not fit.
It is $186 for the OEM 4th gen, $177 for the OEM 4th gen substituting the 5th gen PP, and $143/134 for the Key Value version of both.
Old Sep 29, 2004 | 10:49 AM
95maxrider's Avatar
Lightly modded
Sounds like a good time and good price. I wish I had gotten the 5th gen PP....Do you plan on taking advantage of the extra power handling?
Old Sep 29, 2004 | 10:56 AM
phenryiv1's Avatar
Mod her. Ate her.
No, but it should be more reliable and durable at my current setup.
Old Sep 29, 2004 | 11:18 AM
95maxrider's Avatar
Lightly modded
and easy to use....
Old Sep 30, 2004 | 04:39 PM
95maxrider's Avatar
Lightly modded
The gauges and needles went out for a while yesterday, but then came on again later. What gives?
Old Sep 30, 2004 | 07:12 PM
phenryiv1's Avatar
Mod her. Ate her.
That was those wire taps that we had to use. I did not want to cut the stock wiring, but I don't want you to have continude issues with this. I can fix it, but I was hoping to not have to resort to actually cutting the wires.
dr3am
25
Oct 22, 2015 08:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
cstrasz
Aug 27, 2015 08:07 AM
Flores94
Aug 13, 2015 01:17 PM
