Help Please!!! Car won't start...
Old Sep 27, 2000 | 11:27 PM
brandonj's Avatar
My car finally let me down for the 1st time. Here's the scenario: For a while, to start the car I've had to push the key extra hard and hold it. Tonight, it won't start at all. Accessories all work, battery is good, etc., just won't turn over no matter how hard I press on the key. I think it is the ignition switch, so I took it apart, cleaned up the contacts, and tried it again. Still won't turn over, but I see sparks inside the switch. So my question is, am I right? Is it the switch? Could it be the starter? As always, your help is much appreciated.
Old Sep 27, 2000 | 11:41 PM
buss95max's Avatar
ummmm i dont know if ur having the problem i had b4..but..when my starter messed up on me,
my car would either have a hard time starting or
it wouldnt even make the "starter" noise..i would turn the key and basicly nothing would happen. so what i did was...
i got a wrench and tapped my starter(gently)and vroom my engine started if ur gonna get ur starter fixed by the way..dont get overchargered..ive heard about people spending lots of cash...when really it should only cost at the most 200 with labor and all..hopes this helps u out in some way
Old Sep 27, 2000 | 11:53 PM
brandonj's Avatar
When you say you had a hard time starting your car, do you mean that the starter would go and the car wouldn't start? I hope I don't have to replace the starter...
Old Sep 28, 2000 | 05:22 AM
Wizeguy's Avatar
95-96 have weak starters they seem to last 60,000 - 80,000 miles. They are simple to replace. When mine went, the car sounded like a dead battery... Verrrr..r..r....ummm...
Old Sep 28, 2000 | 06:34 PM
buss95max's Avatar
yeah..it would lagg,it would make the noise wizeguy said...vrrrr--vrrrr..sound like the car wanted to start but couldnt..
Old Sep 28, 2000 | 07:00 PM
brandonj's Avatar
Turned out both the starter and the switch were bad. Luckily, Autozone had a rebuilt starter for $140, and the switch was only $30. 2 hours later, everything is good again. Thanks for the help.
Old Sep 28, 2000 | 07:06 PM
buss95max's Avatar
cool
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
BobMax
Aug 15, 2015 12:35 PM
