HELP, Need O2 Sensor
Old Apr 14, 2001 | 10:30 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I had my new y-pipe installed today and the guy at the shop couldn't get the O2 sensor out of the rear down pipe of the stock pipe. I need to get a new one, but where are the best prices? Also any tips on how to get that one out, i'm gonna give it a shot.
Old Apr 15, 2001 | 06:25 AM
Sprint's Avatar
Vester Nissan in NC - $60
Local Dealerships - $82 - $100
wht kind of shop can't get out an O2 sensor.. that was the easiest thing to get out... tell them to use a wrench and a breaker bar... or give them a subscription to the gym
then can torch it if they must.. just that you would not be able to use it again
Old Apr 15, 2001 | 12:43 PM
They said that they tried the breaker bar but it started to round it self-off. I was thinking about getting new ones anyways. They didn't need to torch it because i would still need a good one. So should i get a bosch one?
Old Apr 15, 2001 | 12:45 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
rounded off? they were probably using standard sockets instead of metric or 12pt or something...i can't believe a shop would have that kind of problem
anyway...stick with OEM on the sensor....
Old Apr 15, 2001 | 12:56 PM
I left them the instructions from the internet with the pipe, and you can't use a 12pt because you have to use an open ended socket on an O2 sensor, i guess i need to save up some cash for a new one now. After i put it in i need to reset my ecu right?
Old Apr 15, 2001 | 02:06 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
yeah reset the ecu....
Old Apr 16, 2001 | 01:25 PM
Isaacm's Avatar
Is it possible to install the O2 sensor incorrectly?
I put my y-pipe in about 2 months ago, and around that same time frame my Maxima started to "miss" a little bit at take-off, and now is just running kinda bad. Did I put it in wrong? Sorry for the dumb question. Just need to know. Thanks!
Old Apr 16, 2001 | 01:27 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Is it possible to install the O2 sensor incorrectly?
did you reset the ECU? i'd try that first...then i would remove and reinstall the sensor...i didn't have any probs after throwing the WSP Y on...
Old Apr 16, 2001 | 01:44 PM
Re: Re: Is it possible to install the O2 sensor incorrectly?
THERE is no sensor to install wrong, i am missing the sensor.
Old Apr 16, 2001 | 01:45 PM
Isaacm's Avatar
While putting on the WSP y-pipe, I had the O2 sensor out, and the negative battery terminal off for about 4-6 hours. Should that have worked? I think it might just be that it went bad around the same time: after all I do have 119,000 miles on original sensor. I should probably just change it.
Now to get on that subject, is Courtesy the best price? and do I have to do any re-wiring?
Thanks for the response!
Old Apr 16, 2001 | 01:51 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Re: Re: Is it possible to install the O2 sensor incorrectly?
my response was to Isaacm...
yeah....i would change it at that mileage...no rewireing is needed...it plugs into the existing harness....apparently a few posts up Sprintmax says Vester nissan is cheaper...i'd call them both to see who beats who...
Old Apr 16, 2001 | 09:19 PM
Re: Re: Re: Re: Is it possible to install the O2 sensor incorrectly?
Sorry
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
