Nismo Radiator Cap
Old Nov 17, 2004 | 09:29 PM
Zack342's Avatar
Nismo Radiator Cap
It does work, notice how my engine temp gauge doesn't even read half
Old Nov 17, 2004 | 10:05 PM
Jeff92se's Avatar
I'm needing a caw
1) What do you expect when you are going 140mph. Plenty of cooling air
2) How do you know that's the optimal operating temp of the engine anyway?
Old Nov 17, 2004 | 10:14 PM
Ant96GLE's Avatar
Mine tends to hover just above the middle and when my bass hits it flutters up and down.. when I get stuck in traffic or going even the slightest incline it will raise just a bit... I want to get auterra and run the temp live to see if its really overheating a bit or if its just the needle going crazy.
Old Nov 17, 2004 | 10:19 PM
Jeff92se's Avatar
I'm needing a caw
That would be the best way as the oem temp guage is very inaccurate.
Old Nov 17, 2004 | 10:32 PM
thisisausername's Avatar
The radiator cap would only make a difference if the coolant was hitting flashover temperature. A different cap could have a different emergency release pressure. A better explanation would be a different thermostat. My orig. thermostat hovered around there, but when I replaced it I got one that opens at a little bit higher temp
Old Nov 17, 2004 | 11:07 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
yea the cap is only gonna raise your boiling point, it wont make your car run any cooler.
Old Nov 17, 2004 | 11:15 PM
FanaticMadMax's Avatar
what's the heck is that blue thing in the middle of your gauge, also I noticed the warning light is on, what does that say, it looks like Engine light. Also, how is it possible going over 140 cuz there is no place in U.S unless a racetrack that you can try to achieve something illegal at that speed. If I tried something like that, I know i would be putting myself in danger that a tire could possible blow at that speed and cause the car to flip. I've seen that happen.
Old Nov 18, 2004 | 05:24 AM
DanNY's Avatar
Ad·min·is·tra·tor
do you constantly want to own yourself over and over??
like someone already said...it raises the boiling point of coolant...doesn't make your coolant cooler. are you that dense that you can't understand that?
Old Nov 18, 2004 | 05:27 AM
Zack342's Avatar
I am planning on getting an OIL pressure and Water autometer gauges but not until christmas. I actaully just bought a Pathfinder Throttle body and waiting to buy the Adaptor plate.i have an hour of dyno time setup this weekend i will dyno with the stock radiator cap and then dyno with the nismo. i hoping for about 5whp what do you guys think?
J/k
Old Nov 18, 2004 | 07:04 AM
Mizeree_X's Avatar
Getting back to his roots
Which esteemed university is giving you a mechanical engineering degree?
Old Nov 18, 2004 | 07:21 AM
Loe max's Avatar
10 CHAR
Old Nov 18, 2004 | 07:29 AM
2k2kev's Avatar
It's chrome alright...
Old Nov 18, 2004 | 07:36 AM
Loe max's Avatar
Thats his ABS light because he pulled his fuse. He can stop faster by out pumping the ABS controller
Old Nov 18, 2004 | 08:42 AM
Zack342's Avatar
I goto Wentworth. Sorry i don't go to Tufts.
Old Nov 18, 2004 | 09:21 AM
NismoMax80's Avatar
SuPeRmOd
with my Nismo cap, the temp gauge is still at half way. Why would you think it only affects temp at the high speeds? terrible logic.
Old Nov 18, 2004 | 10:31 AM
A32Matt's Avatar
for the most part i believe that the Nismo cap is just for looks. won't do anything for performance, won't do anything to help your car...just for looks. I have it on and i don't care if it does a damn thing.
Old Nov 18, 2004 | 10:35 AM
Jeff92se's Avatar
I'm needing a caw
The other terrible logic is taking a damned picture at 140mph+ but that's a whole OTHER subject in the myrid of illogical things going on in this thread and in that pic.
Old Nov 18, 2004 | 10:38 AM
DanNY's Avatar
Ad·min·is·tra·tor
ironically...he's pegging redline and i don't think i see that shift light going off.
Old Nov 18, 2004 | 10:48 AM
Jeff92se's Avatar
I'm needing a caw
And the ABS light is blaring. And...................
Old Nov 18, 2004 | 10:57 AM
Ant96GLE's Avatar
Hes driving with one hand...
Old Nov 18, 2004 | 10:59 AM
Zack342's Avatar
It was turned off for photographic interfarence. Its just there for being there. i used to scare myself driving at night when it came on because it was bright blue and i would think its cops.
i love messing with you guys . take everything so seriously.
FYI JEFF 6500rpm in 5th gear in a 99 4th gen is about 155MPH based on the gearing,my stock tire size and final drive.
Old Nov 18, 2004 | 11:00 AM
Jeff92se's Avatar
I'm needing a caw
You actually think you can go 155? LMAO
Old Nov 18, 2004 | 11:05 AM
Zack342's Avatar
hey if that's what the #'s say that's what i believe.
Old Nov 18, 2004 | 11:07 AM
Jeff92se's Avatar
I'm needing a caw
Don't forget to modulate those brakes really well w/o the abs off also.
Old Nov 18, 2004 | 11:13 AM
NmexMAX's Avatar
dot dot dot ...
He really used an a.ss load of gasoline adn decided to press the trip set button too. . .
Old Nov 18, 2004 | 11:20 AM
Greeny's Avatar
¯\(°_o)/¯
Jeff don't you know that them nismo caps add about 50 horses...
Old Nov 18, 2004 | 11:25 AM
Zack342's Avatar
Easy buddy those were two diffrent ocassions.the 120ishMPh is from thursday morning and the 140+mph is from saturday morning. the
Old Nov 18, 2004 | 11:27 AM
NmexMAX's Avatar
dot dot dot ...
I thought it was obvious I was being sarcastic. . .
Old Nov 18, 2004 | 11:31 AM
Zack342's Avatar
i guess not
Old Nov 18, 2004 | 11:39 AM
2k2kev's Avatar
One day a hunter goes in to the woods with his gun in the hopes of shooting a bear. After a few hours of tracking he felt a tap on his shoulder: it was a huge grizzly bear.
"You're hunting me?", said the bear. "Well, you got two choices. Either I maul you to death or I f*** you up the a**."
The hunter didn't want to die, so he dropped his drawers and let the bear f*** him. The bear left satisfied and the hunter went back to his cabin.
After a horrible nights sleep, the hunter decided that he was going to kill the bear, so he went out hunting. After a few hours of tracking the hunter once again felt a tap on his shoulder. Again, the bear gave him two options.
"Either I maul you to death or I f*** you up the a**." The hunter dropped his drawers, bent over, and let the bear have his way with him.
Back at his cabin that night, the hunter couldn't sleep and decided right then and there that he would go out, find the bear, torture him and and kill him! Not waiting for morning the hunter went out in search of his cave.
After tracking the bear for several hours he stood at the mouth of the cave where the bear slept. As he was creeping in, he felt the familiar tap on his shoulder,
"You're really not out here to go hunting, are you?"
You're really not here for the cars, are you?
Old Nov 18, 2004 | 11:43 AM
Zack342's Avatar
That's a good one. I do like the maxima but i think i have taken my maxima as far as it can go. i am just here to help out the noobs and mess with you guys. i only got the radiator cap for looks, heck if i know if it lows temps. you find this just as entertaining as i do.
Old Nov 18, 2004 | 11:46 AM
Jeff92se's Avatar
I'm needing a caw
Maybe as far as YOU can take the maxima, but you haven't even gone 1/2 way on this thing. But you know........
That's a good one. I do like the maxima but i think i have taken my maxima as far as it can go. .
Old Nov 18, 2004 | 11:50 AM
Zack342's Avatar
yeah but i want something else.i would have loved to get mevi and an ECU but it ain't going to happen without me hacking up some stuff. i bought a PF throttle body so i will install that once i get the adapter plate. I will probally get an SAFC II since they are really cheap now and that will be it. Sure i can supercharge it or turbocharge it but that is $5000 i can use toward a nice car. i plan on keeping my max.its pretty quick and it's ok on gas i get about 23MPG.
Old Nov 18, 2004 | 11:51 AM
A32Matt's Avatar
this thread needs to die....really
2k2kev's Avatar
You keep doing this and it's pretty pathetic.... post something, get knocked down because you think you're smarter than you are, try to defend yourself but again, you're not that smart so it fails, then you say you're here to "help the noobs" and "mess with us"
.......but you don't know more than noobs except how to install a hideous eyeball.
.......and we really know that whole "mess with you" thing is a cover for your lack of anything useful to add.
Go away.
Old Nov 18, 2004 | 11:53 AM
Jeff92se's Avatar
I'm needing a caw
Old Nov 18, 2004 | 11:55 AM
NmexMAX's Avatar
dot dot dot ...
Hacking up what stuff for a MEVI/ECU? I'm not an engineer, but I didn't "hack" anything up in the process of swapping mine.
The MEVI is a mechanical device, you should be okay with that part, but the ECU, it's electronic.. . . OOhh, might need a EE for that one.
Old Nov 18, 2004 | 12:00 PM
Zack342's Avatar
For me to get the ECU to work i would have to "hack UP the harness" and move pins around but i thank you for sharing your experience.
Old Nov 18, 2004 | 12:02 PM
Zack342's Avatar
i do help the noobs you guys just flame them then think your so useful
Old Nov 18, 2004 | 12:03 PM
A32Matt's Avatar
i would have to second that notion (no offense everyone)
