Installing 300ZX brakes, need tips...
Old 11-23-2004, 11:42 AM
  #41
I'm needing a caw
Jeff92se's Avatar
Did any of those bbk equipped cars have upgraded rears also?? Again, there is a big reason cars come with huge rotors now. It's not all about fade resistance or feel. You can accomplish both without huge rotors. But you don't have to believe me. Just drive someone's car that has a bbk on it.
But I fail so see what the difference inbetween "fade resistance" and "decrease fade". Seem one in the same to me?
"The big decrease in distance(over OEM) happens when going at higher speeds" Anything at 60mph and above is higher speeds to me.
Originally Posted by MAX2000JP
From Stoptech website:
"A big brake kit will provide increased heat capacity, which means substantially more resistance to brake fade and caliper distortion with multiple stops from high speed. A firmer pedal due to stronger and stiffer components, as well as better modulation characteristics under threshold braking are also typical with a properly balanced brake upgrade. "
You aren't reading correctly, I never said that "BBKs only are for fade resistance". I said they decrease fade and increase feel. This is due to the increase in numeber of pistons. A larger number of pistons means increased feel. Therefore, the 300ZX calipers will be much better than the OEM stockers. If you look at the actually distances gained by BBK's they are minimal. Checkout the Supercar challenge or tests of tuner cars. Often if all things are equal, the braking distance is decreased slightly. The big decrease in distance(over OEM) happens when going at higher speeds. This is because a BBK can better disapate heat.
Jeff92se is offline
Old 11-23-2004, 11:43 AM
  #42
MAX2000JP's Avatar
Originally Posted by TopElement
Have you ever driven a maxima with a big brake kit? I can take full advantage of my brakes without having to use R compounds. The brakes are the single best improvement I've made to my cars. Dinky stock size rotors, pads, and SS lines don't do **** compared to the numerous advantages of a whole new set of much better parts. Even for day to day driving, they make a huge difference. High speed freeway driving no longer makes me worry about brakes, as stopping several times from 120+ is not an issue.
The biggest problem with slide-rail calipers centers around the most important issue in braking: release. That you can "lock them up anytime I want" is NOT a good test of a braking system. On the contrary. The real issue in performance braking is not the clamping force, but release and how quickly and precisely you can take the force OFF the rotors to keep that knife edge of balance. Slide rail calipers just don't -- can't -- release rapidly and smoothly enough. On maximas with ABS, it's even easier to take full advantage of the increased stopping power. Look at the system: with the application of pressure through the hydraulics, slide rails must move the caliper against both sides of the rotor. To release the clamping force they must move the same distance, back. On the other hand, pistons move a fraction of that distance to clamp and unclamp the pad to the rotor. Piston calipers equal more braking force controllability, which equals greater ability to feather your brakes. The result translates into lots more finesse!
Fixed piston calipers -- with pistons on both sides -- are designed to deliver more consistent force across the brake pad. That's why four-piston calipers are more precise than two-piston ones, given the same installation design. Here, I need to note that radial-mount calipers, like the systems I sell, enhance this intent compared to lug-mount calipers, like 300zx. First, because the radial mounts, that are perpendicular to the diameter of the rotor allow for more leeway in where/how you need to mount them; and second, because the wider the gap between the mounts, the stiffer the caliper -- some of the lug-mount calipers have a 3 1/2" gap, some have 6" -- which again affects how evenly the clamping force is delivered to the pad. But some wheel configurations don't allow for radial mount. And lug-mounts are definitely much less expensive.
I could go on and on about 2-piece rotor advantages, but i don't feel like typing that much for someone like you. Suffice it to say that my 13.1" rotors and 4 piston calipers weigh about 1/2 as much as the chunks of iron that Nissan calls stock brakes. So my acceleration, steering, and ride quality are improved. More than just stopping benefits are had when upgrading the brake system.
Unsprung weight does improve braking, handling, etc. You could go one step further and say a Carbon ceramic braking system has even more of these advantages. I am fully aware of this....
You will not fully use 100% of the potential of YOUR brakes without a sticky tire. If you think otherwise, argue somewhere else. You cannot tell me that your braking wouldn't be improved with a r-compound that was at track temperature.
MAX2000JP is offline
Old 11-23-2004, 11:46 AM
  #43
I'm needing a caw
Jeff92se's Avatar
Not making sense. Any brake system would benefit. Also any brake system would be hurt by inferior tires also. It's just that with a bbk, braking is that much better in all situations.
Jeff92se is offline
Old 11-23-2004, 12:16 PM
  #44
MAX2000JP's Avatar
Exactly, this was my point 15 posts ago when I said tires are the factor for decreasing stopping distance
There are a few basic facts that must always be kept in mind when discussing brake systems: Source Stoptech
1) The brakes don't stop the vehicle - the tires do. The brakes slow the rotation of the wheels and tires. This means that braking distance measured on a single stop from a highway legal speed or higher is almost totally dependent upon the stopping ability of the tires in use - which, in the case of aftermarket advertising, may or may not be the ones originally fitted to the car by the OE manufacturer.
2) The brakes function by converting the kinetic energy of the car into thermal energy during deceleration - producing heat, lots of heat - which must then be transferred into the surroundings and into the air stream.
The amount of heat produced in context with a brake system needs to be considered with reference to time meaning rate of work done or power. Looking at only one side of a front brake assembly, the rate of work done by stopping a 3500-pound car traveling at 100 Mph in eight seconds is 30,600 calories/sec or 437,100 BTU/hr or is equivalent to 128 kW or 172 Hp. The disc dissipates approximately 80% of this energy. The ratio of heat transfer among the three mechanisms is dependent on the operating temperature of the system. The primary difference being the increasing contribution of radiation as the temperature of the disc rises. The contribution of the conductive mechanism is also dependent on the mass of the disc and the attachment designs, with disc used for racecars being typically lower in mass and fixed by mechanism that are restrictive to conduction. At 1000oF the ratios on a racing 2-piece annular disc design are 10% conductive, 45% convective, 45% radiation. Similarly on a high performance street one-piece design, the ratios are 25% conductive, 25% convective, 50% radiation.
3) Repeated hard stops require both effective heat transfer and adequate thermal storage capacity within the disc. The more disc surface area per unit mass and the greater and more efficient the mass flow of air over and through the disc, the faster the heat will be dissipated and the more efficient the entire system will be. At the same time, the brake discs must have enough thermal storage capacity to prevent distortion and/or cracking from thermal stress until the heat can be dissipated. This is not particularly important in a single stop but it is crucial in the case of repeated stops from high speed - whether racing, touring or towing.
4) Control and balance are at least as important as ultimate stopping power. The objective of the braking system is to utilize the tractive capacity of all of the tires to the maximum practical extent without locking a tire. In order to achieve this, the braking force between the front and rear tires must be nearly optimally proportioned even with ABS equipped vehicles. At the same time, the required pedal pressure, pedal travel and pedal firmness must allow efficient modulation by the driver.
5) Braking performance is about more than just brakes. In order for even the best braking systems to function effectively, tires, suspension and driving techniques must be optimized.
For maximum brake potential, vehicles benefit from proper corner weight balance, a lower CG, a longer wheelbase, more rear weight bias and increased aerodynamic down force at the rear
Old 11-23-2004, 12:18 PM
  #45
I'm needing a caw
Jeff92se's Avatar
Nice copy / paste. If you think your stock brakes are fine because you can slam the pedal down and lock them up, go ahead and keep thinking that.
It's funny that you think Nissan went to great pains to design your brakes. Considering they are nearly idenctical to the 4-gen and 3-gen systems. The only difference being the weight kept going up. And that post sums up my point regarding the 5-gen brake rotor problem nicely.
Jeff92se is offline
Old 11-23-2004, 12:21 PM
  #46
MAX2000JP's Avatar
I copied and pasted to show the misinformation in your arguement and even some of mine. Carrol Smith and Stoptech are valid sources, instead of the both of us just argueing.
Old 11-23-2004, 12:26 PM
  #47
I'm needing a caw
Jeff92se's Avatar
If the tires are the overwhelming factor stopping the car, then why not just use really thick rotors that are just 10" in diameter?? You just admitted that large rotors help. BUT you stated those cars I mentioned are for track duty. But that also confirms my point that large rotors actually do help stopping distance. Correct? Or else you would have said, cars with large rotors (despite what car they are installed) doesn't do anything. Then you just posted a link that said "the stopping distances are improved from high speeds". That again supports my case. If it's truely the tires and not the BBK, the speed of the vehicle would not matter. Just the tires. I'm not argueing about the fade resistance or feel. As I agree with you. BBKS greatly help both.
Jeff92se is offline
Old 11-23-2004, 12:29 PM
  #48
MAX2000JP's Avatar
Nissan used the same brakes for fiscal purposes. From my experience, the 5th gen rotors warp because of the pads. I changed to a different pad and have had no issues. Have you ever read Carrol Smith's article on "Why warped discs arent caused by heat"?
Old 11-23-2004, 12:31 PM
  #49
Getting back to his roots
Mizeree_X's Avatar
I just want to re-iterate TopElement's question: Have you driven a Maxima with a BBK? I installed a 4-wheel BBK on my car and experienced a very real decrease in stopping distance, and I doubt all of it was due to the new brake fluid I added when I swapped calipers.
Mizeree_X is offline
Old 11-23-2004, 12:32 PM
  #50
Zack342's Avatar
MAX2000JP let it go man....... its not worth it
Zack342 is offline
Old 11-23-2004, 12:34 PM
  #51
I'm needing a caw
Jeff92se's Avatar
No but I read this:
Are stating that this is not correct? Because you just posted it.
But this is the brake setup that you say is just fine. Even though these brakes were just okay with the 3-4th gens. Add a few more hundred lbs and don't change the design at all. And look what happens. Many rotor warpage problems. If the warping was truely the pads, how come the 3-gens/4-gens aren't experiencing NEARLY the warpage rate? Did Nissan start using different pads for the 5th gen?
Jeff92se is offline
Old 11-23-2004, 12:36 PM
  #52
MAX2000JP's Avatar
Ask Carrol Smith that...I am not "expert" on the subject myself. You mentioned the Vette, Porsches, BMWs. These cars are track tested on the Nurburgring and various road course. Team Corvette tested a bunch of different brake ducts to get the temperature right when testing in Germany. These cars have performance suspensions, which in conjunction with good brakes and tires, produce amazing results. Stopping distances are improved at high speeds again because of the better thermal properties of a BBK. A lot of thermal energy is created from a 80-0 or 120-60 stop. More area means better disapation of heat and more predictable stopping. Maybe I should have said, less fade equals better stopping distances.
Old 11-23-2004, 12:37 PM
  #53
MAX2000JP's Avatar
No but I read this:
My answer would be this: Interesting read BTW.
http://www.stoptech.com/whitepapers/...otors_myth.htm
Old 11-23-2004, 12:40 PM
  #54
I'm needing a caw
Jeff92se's Avatar
Are you now saying that the previous statements you copied pasted are now incorrect?
Jeff92se is offline
Old 11-23-2004, 12:42 PM
  #55
MAX2000JP's Avatar
Please read it first...theres no way u could have read all that information by now
Both articles are written by the same guy btw.
Edit:
Pads on the 4th gen and 2000-2001 pads are different. Different SKU numbers per Courtesy parts. Does this mean they share different compounds, I dont know.
Old 11-23-2004, 12:46 PM
  #56
I'm needing a caw
Jeff92se's Avatar
But why even have big rotors at all? According to you they do nothing. It wouldn't matter what car they are installed on.
So let's say I could magicly install the Porsche optional huge 14" brakes with the carbon fiber rotors, it would do absolutely nothing because my maxima suspension is not "optimal"??? Or it's FWD?
Actually you should not say that. A larger torque arm advantage from using a larger rotor and a caliper further away from the centerline of the rotor will apply more braking force onto the rotor. If you could elminate all fade and with all other factors being equal, the sytem with the larger rotors will stop sooner. Now add fade. The system with the larger rotors will still peform better in areas of fade resistance and stopping distance.
Jeff92se is offline
Old 11-23-2004, 12:48 PM
  #57
I'm needing a caw
Jeff92se's Avatar
I only read your statements. Which contradict themselves.
This is what you need to find out.
Jeff92se is offline
Old 11-23-2004, 12:50 PM
  #58
MAX2000JP's Avatar
Those statements were made by Carrol Smith, which shows your arguement to be incoherent. Again, I am no expert on braking systems. I would take Carrol Smith numerous years of racing as a valid source.
Old 11-23-2004, 12:52 PM
  #59
I'm needing a caw
Jeff92se's Avatar
Okay I guess it's not conversation. Just a cut/paste thing. And you shouldn't just copy/paste unless you are ready to discuss what you are pasting. It's clear that you might not.
Jeff92se is offline
Old 11-23-2004, 12:53 PM
  #60
MAX2000JP's Avatar
Reading compreshension ownz u....I never stated big rotors do nothing. I specifically stated they increase feel and remove energy more effectively.
Old 11-23-2004, 12:55 PM
  #61
MAX2000JP's Avatar
I cited the source.....I also find it interesting about the contradiction seem in those 2 articles. Maybe we should email Carrol Smith for some further information?
Old 11-23-2004, 01:01 PM
  #62
I'm needing a caw
Jeff92se's Avatar
Here's another one. You quote StopTech's site to support your theory that bbk that use large rotors don't help.
But StopTech offer just that. Kits that ultilize larger rotors/multipiston calipers.
Jeff92se is offline
Old 11-23-2004, 01:05 PM
  #63
I'm needing a caw
Jeff92se's Avatar
How exactly do they do that?? Because they are bigger? Or because they have more mass??? Let's assume the logical and say because they have more mass. Is that correct??
Jeff92se is offline
Old 11-23-2004, 01:06 PM
  #64
MAX2000JP's Avatar
See you are misinterpretting me...I never never said BBKs are useless. Under extreme conditions, such as road racing they are crucial. My arguement was/is that they dont improve stopping distances as much as people think. When braking multiple times hard, they do because of the greater thermal properties they exhibit.
Old 11-23-2004, 01:08 PM
  #65
I'm needing a caw
Jeff92se's Avatar
just answer this
Jeff92se is offline
Old 11-23-2004, 01:09 PM
  #66
Mizeree_X's Avatar
Hey look, I can copy and paste too (from the same Stoptech article):
"A few things are now obvious:
1) Line pressure can only be increased by either increasing the mechanical pedal ratio or by decreasing the master cylinder diameter. In either case the pedal travel will be increased.
2) Clamping force can only be increased either by increasing the line pressure or by increasing the diameter of the caliper piston(s). Increasing the size of the pads will not increase clamping force. Any increase in caliper piston area alone will be accompanied by an increase in pedal travel. The effectiveness of a caliper is also affected by the stiffness of the caliper body and its mountings. It is therefore possible to reduce piston size while increasing caliper stiffness and realize a net increase in clamping force applied. This would typically improve pedal feel.
3) Only increasing the effective radius of the disc, the caliper piston area, the line pressure, or the coefficient of friction can increase brake torque. Increasing the pad area will decrease pad wear and improve the fade characteristics of the pads but it will not increase the brake torque."
Jeff's or Matt's BBK: larger rotor radius, larger caliper piston area. These increase the clamping force as well as the BRAKE TORQUE, which in turn affects stopping distance.
Now, a few caveats: Do tires make a difference? Of course they do. Even with 10-piston calipers and 15" rotors and a perfectly balanced brake bias, they wouldn't improve a thing if the tires do not provide adequate traction to keep the car in contact with the ground. HOWEVER, the stock Maxima braking system does NOT bring the tires to their traction limit (obviously this is highly dependent on the tires on the specific car, I only have experience with Maximas I have driven). However, we can reasonably assume that someone who is thinking about purchasing a BBK has also invested in tires that provide a high level of dry traction. So, you can see tangible benefits from bigger brakes without changing tires if you are still operating within the traction limit of said tires.
Old 11-23-2004, 01:11 PM
  #67
MAX2000JP's Avatar
To put it simply....Surface area.
If you get a chance, read this also: Explains basically all we are discussing.
http://www.stoptech.com/whitepapers/...ons_122701.htm
This is why I would buy from Stoptech, they are honest.
"In order to brake effectively, the tires must comply with and grip on the road. Your braking system is no better than your tires and suspension. The best money that you can spend is on really good tires and really good shocks."
"If the braking system is only marginal, upgrading the pads and brake fluid and/or getting more air to the system will probably cure the problem at minimal cost. Replacing the stock rubber flexible hoses with stainless braid armored Teflon hoses will improve the ability to effectively modulate the braking force at moderate cost."
Old 11-23-2004, 01:15 PM
  #68
I'm needing a caw
Jeff92se's Avatar
Surface area? What if the rotors were 19" in diameter but only 0.5" thick? Lots of surface are right?
Jeff92se is offline
Old 11-23-2004, 01:23 PM
  #69
MAX2000JP's Avatar
You are really picking at straws here. Please read the last link I provided you, it will answer that question for you.
Old 11-23-2004, 01:42 PM
  #70
I'm needing a caw
Jeff92se's Avatar
You only mention that it's the brakes ability to handle the heat that's repsonsible for better brake distance. That IMHO is false. From all the people that have installed the 300z calipers/pads/rotors, none have reported better performance in the dist dept. This was also mentioned by Shadow and is repeatly mentioned by Miseree and your own link. Why is that? The 300z calipers and rotors both feature increased performance in piston area and thermo mass capabilities. According to you, because of these two things only, braking dist reduction should have happened. But has apparently has not. Why is that only when these same parts are coupled with a rotor that puts the caliper futher away from the centerline does the braking performance increase?
Understand that and we don't have an arguement.
Jeff92se is offline
Old 11-23-2004, 02:01 PM
  #71
Ad·min·is·tra·tor
DanNY's Avatar
MAX2000JP...i assume you don't have a BBK? you're basically taking 3rd hand information? bench racer? drive a car w/ BBK and then draw your own conclusions instead of copy and pasting what others say.
also how realistic is R compound for street use?
DanNY is offline
Old 11-23-2004, 02:35 PM
  #72
MAX2000JP's Avatar
That is what I said on page 1, again you arent reading my posts correctly.
Old 11-23-2004, 02:37 PM
  #73
MAX2000JP's Avatar
No, I dont own a BBK. IMO it's a waste on a Maxima, since it will never be anything close to a competent racecar. I would buy a BBK on a track car and that's where I would run R compounds.
Old 11-23-2004, 02:41 PM
  #74
Ad·min·is·tra·tor
DanNY's Avatar
hmmm ok fair enough.
well i can't speak for others but personally i'm very hard on my brakes...but on a street level. a lot of NYC stop and go and fast braking. i've experienced some fading in the past and i feel the BBK is the best upgrade for what i need it for. it stops shorter and resists fading a lot better. that shorten distance saved me a few times when i have those dum dum cabs cut me off and slam on the brakes.
DanNY is offline
Old 11-23-2004, 02:58 PM
  #75
MrGone's Avatar
IMHO BBK's are a waste on street cars, but on the track work well.
Donkeys BBK saved him from hitting a deer shortly after he installed his.
MrGone is offline
Old 11-23-2004, 02:59 PM
  #76
I'm needing a caw
Jeff92se's Avatar
You aren't addressing my questions but who cares now? If you agree that using larger rotors benefit stopping dist and that is partially accomplished by the increased torque arm, then we don't have a problem. Because you have then agreed to all points.
Jeff92se is offline
Old 11-23-2004, 03:05 PM
  #77
Zack342's Avatar
MAX2000JP give up man i feel so bad for you. between Jeff and his Minions your going to keep getting owned even though you have had some valid points.
Zack342 is offline
Old 11-23-2004, 03:06 PM
  #78
I'm needing a caw
Jeff92se's Avatar
Why don't you either stay out of it or state your points. I asked NO ONE to stand up for me. If I was wrong, they would have said so.
Jeff92se is offline
Old 11-23-2004, 03:07 PM
  #79
Ad·min·is·tra·tor
DanNY's Avatar
you want some of this too punk?
DanNY is offline
Old 11-23-2004, 03:10 PM
  #80
Zack342's Avatar
No, I have had my share but I am gaining an extensive Knowledge of braking and brake components. This is a great thread. Also who are you calling a punk? What is your definition of Punk based on?
Zack342 is offline
Quick Reply: Installing 300ZX brakes, need tips...
