Suspension install and brake line question.
I was wondering if changing the struts on the maxima involes removing the brake lines. On my friend's subaru, we had to remove the brake lines to install the struts. I was planning on changing my brake pads and lines soon. But before I get my new suspension. So I was wondering if I would be doing double the work (bleeding brakes).
ZuM
ZuM
On the 3-gens it's not needed to remove the brake lines. On the 4-gens I'm almost 100% sure it's not necessary. Some cars to require you to remove the brake lines to do suspension work but not in the maxima's case. It's becuase sometimes the brakes lines go through a hole in the strut bracket and you can't get the strut off w/o removing the line. On maximas the line is bolted on w/ a few 10mm bolts.
ZuM
ZuM
Thanks guys. =) I can do my brake install with peace of mind now. =)
ZuM
ZuM
Anyone have a good link a description of this process?
Oh, on a 4th gen the brake line is clipped to the strut with a medal clip. You can pop it right off with a screw driver.
You don't have to drain the fluid first. But some will come out. What you do is make sure you seal the brake fluid resevior in the engine bay. You can do this by putting cling wrap (plastic wrap) around the opening and putting the cover on. The vaccum will keep the fluid in. But some will come out.. And you will have to bleed all the fluid out of the braking system after you are done with the lines.
ZuM
ZuM
Originally posted by ejj5875
How exactly do you change the brake lines? I was thinking of doing it this summer, but I've never done it. Do you have to drain the break fluid first, or do you just let it spill
Also, be sure to use a flare nut wrench on the fitting at the other end of the brake line. If you don't, you will round off the bolt. If you do round it off, use some vice grips. Trust me, it works
Finally, take it easy when trying to open your bleeder screws. If they break, you might end up replacing the entire caliper. ($$$)
Roman777NYC
Nov 7, 2015 10:13 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
