More 00VI talk...this time motor.
Old Dec 21, 2004 | 05:16 PM
dmontzsta's Avatar
Ford Only.
I have been reading up on the 00VI and it seems great. I know it is possible to put the VQ30DE-K into a 4th gen, but would it be easier to put the a 2000-2001 5 Speed ECU and Wiring Harness in? along with the motor and VI setup? that way you dont have to try and work around anything. Can you think of any codes that would pop up? I have been checking them out and the sytem seems pretty close, minus the vacuum for the VI. Can some of you that are more educated on this throw some input in?
Old Dec 21, 2004 | 06:15 PM
BSwithTF's Avatar
I thought about this when I got my motor. Included (much to my suprise) was a fully intact wiring harness. Usually, they don't want to mess with it and cut the harness at the firewall. Biggest reason I didn't do it was to keep my JWT ECU. I wouldn't have any codes if I hadn't messed with the EGR stuff and I'm pretty sure thats fixable if I could ever find the time to sit down and mess with it a little.
Swapping wiring harness's sounds like a lot of work, though.
Old Dec 21, 2004 | 06:28 PM
dmontzsta's Avatar
Ford Only.
My shop that has done my tranny swap in both cars will swap the wiring harness for $200. My current motor has 180+k, I think I might start searching for a complete VQ30DE-K (unless someone thinks it will not work). Then he would charge me $400 to swap motors, $200 to swap the harness and ECU. If I have no codes. I would really do this if I knew there would be no codes. Wouldnt that put me at around 190whp/190wtq stock? in a 3,050lb car, then with mods I should be pushing 210whp/210wtq.
Old Dec 21, 2004 | 06:35 PM
BSwithTF's Avatar
Sounds good. If you've got someone who'll do it for those prices, might as well give it a shot. I don't see any reason why it wouldn't work.
Old Dec 21, 2004 | 06:38 PM
deezo's Avatar
Do a 3.5 Liter swap.
Old Dec 21, 2004 | 07:17 PM
MrGone's Avatar
Old Dec 21, 2004 | 09:07 PM
HTPerformance's Avatar
i dont see any problem with the swap... as long as you are swapping apples and oranges it is kosher.
Brian
Old Dec 21, 2004 | 09:32 PM
dmontzsta's Avatar
Ford Only.
It is a good idea, but then you run into a little more trouble with the drive by wire and I would have to get a 6 speed trans (I think) either way it would be more cash. My main goal is no check engine light.
Old Dec 21, 2004 | 10:21 PM
MrGone's Avatar
The benefits of the 3.5l heavily outweight the costs.
Easiest way to get rid of the CEL is sell the minima
Old Dec 24, 2004 | 09:11 PM
Nismo3112's Avatar
Custom User Title
Hmm you could always take the CEL bulb out.
mvm062
Nov 30, 2020 09:00 AM
Finkle
Sep 27, 2015 09:53 PM
intimidator
Sep 5, 2015 07:23 PM
Maximeltman
Aug 31, 2015 01:01 PM
