Battery relocation
Old Jan 7, 2005 | 07:13 AM
euromaxima's Avatar
Battery relocation
I want to relocate my battery to the trunk. I orderd some t blocks on the net one for the ground and one for power. My question is this. I plan on all my neons, tv and a few other little things are in the enginebay. If I plug all them in the t block will 1 gauge wire be big enough? My stereo and air suspension runs off a seperate power wire coming from the trunk so I will just shorten that wire. as for the ground i was going to plug all them to the oter t block and run 1 gauge to the rear as well. Will this work.
thanks
Brandon
Old Jan 7, 2005 | 08:05 AM
gtr_rider's Avatar
192.168.1.1
Give this a whirl, see if it sets you in the right direction... http://www.merkurencyclopedia.com/El...elocation.html
Old Jan 7, 2005 | 05:00 PM
FanaticMadMax's Avatar
Good luck with that. I wouldn't advise that, since you have to keep in mind that if you were to put it in the trunk, how would you secure it down. It has it be tied down, otherwise the battery can tip over and get acid leak all over your trunk and eat away the metal. You would need a very very long cable from the trunk to the engine compartment. It would be a pain if you would need to jump your car if you had it in the trunk. I know, cuz I have a E320 and it located under by the spare tire.
Old Jan 10, 2005 | 03:12 PM
japmaxSE's Avatar
Go Get a Life!
I don't know about your setup but try not to put to many wires on one block keep it simple and don't forget your fuses for your miscellaneous items and switches. I blew a few during mine it took me 2 1/2hrs to do tedious but simple.
Old Jan 11, 2005 | 04:02 AM
Nozama's Avatar
Grumpy old guy
If you use an Optima battery and a battery tray screwed to the floor on the left side of the trunk as shown above... No acid leaks and tied down (personally I wouldn't use an open cell battery in the trunk)
And actually since most cars are driven forward into a parking spot, it's easier to boost.
Mercedes don't count since you have to remove the rear seat bottom or the spare tire on the newer models.
Old Jan 11, 2005 | 08:44 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
mine is in one of those marine battery cases that they sell at autozone. straps in easily.
make sure your ground is good. mine is to a couple of places, the main on is the strut tower.
Old Jan 11, 2005 | 11:55 AM
DAVE Sz's Avatar
Hooooooonda.....
Yeah, $12 gets you a big enough box for almost any size battery.
Old Jan 11, 2005 | 01:45 PM
japmaxSE's Avatar
Go Get a Life!
I made my own box to cover the battery but I don't like the looks of it. I may consider getting the marine box from autozone..
Old Jan 11, 2005 | 10:29 PM
maxima98vspec's Avatar
i just love the extra space under my hood, i can sleep in there
Old Jan 12, 2005 | 03:05 AM
Jason R's Avatar
aka UNCDooD
looks good. can't wait to do mine.
Old Jan 12, 2005 | 11:26 AM
1MAX2NV's Avatar
There is a nice billet battery tray made for Optima on ebay. Too bad it doesn't fit our Optima battery size. I think we take group 35 battery size. The price is more than fair compare to other battery box on the market.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Here's a univeral one but it doesn't look as nice as the other two.
Old Jan 12, 2005 | 11:40 AM
euromaxima's Avatar
im making my own doing metal work
then im going to paint it the color of my car.
Old Jan 14, 2005 | 10:57 AM
1MAX2NV's Avatar
I just checked my Optima battery. It's a size 34. I'm going to try to get one of those Billet tray.
Old Jan 14, 2005 | 12:36 PM
Jason R's Avatar
aka UNCDooD
damn. i wish they made one that would fit the series Optima battery that i have.
Old Jan 14, 2005 | 12:48 PM
goodhead's Avatar
just curious, the negative wire i can ground anywhere right? and the positive wire i can jsut connect to the old connection??? or do i have to put a fuse or soemthing there
Old Jan 14, 2005 | 01:45 PM
1MAX2NV's Avatar
Negative should be grounded to a clean body. I would put a fuse on the power wire. I'm plan on moving my main fuse for my 0 gauge to the trunk.
Old Jan 14, 2005 | 01:51 PM
goodhead's Avatar
ypu losted me there, can you direct me to the fuse i would need? you are going to use a 0 gauge wire? i was gonna get a 2 or 1 gauge, what the difference? also the clean body jsut sand off the paitn till bare metal then drill hole and attach the wire?
also there is this gooey stuff that help conduct electricity, for got the name of it but i used it on my headlight bulb harness when using overwattage bulbs, anyone know what im talking about?
Old Jan 14, 2005 | 06:13 PM
Jason R's Avatar
aka UNCDooD
where did you get your 0 guage wire at?
Old Jan 14, 2005 | 09:17 PM
goodhead's Avatar
ok ao i took a look at my battery, the positive connection has 1 wire going to the starter, and 2 going to the fuse box, and a little loop between the 2 going to the another part of the starter...i think. how would i connect these?
Old Jan 14, 2005 | 09:35 PM
DAVE Sz's Avatar
Hooooooonda.....
Why in the world would you put a fuse on the +power wire? That is pointless.
Old Jan 14, 2005 | 10:32 PM
dmontzsta's Avatar
Ford Only.
All ready for a turbo now...
Old Jan 15, 2005 | 10:16 AM
goodhead's Avatar
Originally Posted by TopElement
You must have a fuse on the "+" cable, as close to the battery as possible.
If you don't have a fuse, then you would have like 10 feet of cable that will burn and probably start a fire if the insulation is damaged and the cable touches the chassis.
what type of fuse? doent they come in diff strength?
japmax, yeah i think im find something like this
and put the 2 fuse wire and the sarter wire to it
Old Jan 15, 2005 | 12:14 PM
japmaxSE's Avatar
Go Get a Life!
You need an independent fuse located close to your battery it will be a 0 gage fuse holder and fuse any Car Stereo Store will have this they do relocations all the time.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
