Spontaneous camber change
Old Jan 23, 2005 | 02:21 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
If I'm driving down the rode, hit a small bump and my wheels go from | | to / \ ... what do you guys think the problem is. Nothing is loose as far as bolts go.
Old Jan 23, 2005 | 06:32 AM
Micah95GLE's Avatar
How do you know your wheels are doing that? You can't see your wheels while you're driving.
Good suspensions are designed to add negative camber in compression, to maintain grip. If the suspension didn't add negative camber, then the body roll would cause the camber to go positive, which would significantly reduce grip.
Old Jan 23, 2005 | 07:05 AM
njmaxseltd's Avatar
Check for failed lower control arm bushings (where it mounts to the sub-frame) and make sure the ball joint is tight.
Old Jan 23, 2005 | 08:38 AM
BEJAY1's Avatar
Conecarver
Bounce on car above the strut and see what might make noise/be loose. Jack one of the front wheels and grab it. Try moving it in/out - does it do wiggle any besides normal turning?
Old Jan 23, 2005 | 06:15 PM
Broaner's Avatar
2060lbs and falling...
Maybe its your front engine mount... LMAO
Old Jan 23, 2005 | 06:21 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
seximagtrBroaner
Old Jan 23, 2005 | 07:20 PM
Broaner's Avatar
Originally Posted by VeeQueue
seximagtrBroaner
http://forums.maxima.org/showthread....=1#post3600767
Specifically page 4 & 5.
Old Jan 26, 2005 | 01:16 PM
SPiG's Avatar
SomePsychoGuy
Please don't hijack this thread too. Personal attacks are better left in PMs.
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
