Yet another BBK idea...
Old Feb 9, 2005 | 12:35 PM
mzmtg's Avatar
Minister of Silly Walks
I don't know if this has been brought up or not but here goes...
I've been trying to come up with a decent brake up grade that will fit under the factory 16" SE wheels. As far as I know, 300ZX calipers dont clear the wheels. So what about usinga twin piston sliding caliper from another Nissan? This would allow for a bit larger pad and more clamping force. It also might not throw off the brake bias as much when used with stock rear brakes.
I know the Xterra uses a twin piston caliper, as do some other japanese sedans.
Anyone got anything to add to this idea?
Old Feb 9, 2005 | 12:48 PM
Jeff92se's Avatar
I'm needing a caw
That might work. But you need to verify the dimensions/offset/mounting of the caliper vs oem. But from most reports of people using even the 4 piston caliper, didn't really report any better braking when they used the stock sized rotor. They DID however report much better fade resistance.
So depends on what you are looking for. More fade resistance? This might work. But if you want better braking dist control, IMHO you need to have bigger rotors. Don't know what rotor/caliper will fit under an oem 16" wheel.
In theory, using a twin/quad piston caliper should provide more clamping force thus better braking. But doesn't seem to be the case. Or if it is the case, the improved clamping force is not readily noticable.
Old Feb 9, 2005 | 01:06 PM
Larrio's Avatar
The Definitive AE Master
the cefiros in taiwan have a upgraded OEM nissan two piston caliper that should mount the same and use the same size rotor.
might want to inquire daveb if any of those parts are possible to get here
Old Feb 9, 2005 | 01:08 PM
mzmtg's Avatar
Fade resistance is the goal. Being able to use a larger pad and possibly a thicker rotor (stock diameter) should reduce fade, right?
Old Feb 9, 2005 | 01:09 PM
Mizeree_X's Avatar
Getting back to his roots
Q45 calipers maybe? I heard they are 2-piston. Maybe even Q45 rotors too? I have no idea what that setup is, but it is something to look into.
Old Feb 9, 2005 | 01:11 PM
Larrio's Avatar
correction, maybe not OEM.
but look here and down the page
http://www.vcar.com.tw/a609/p4.htm#cefiro
Old Feb 9, 2005 | 01:18 PM
Jeff92se's Avatar
I'm needing a caw
I have heard that the 3-gens in UK used 2 piston calipers as stock equipment. But even if you could find a set (rare), shipping them over would be expensive.
I believe the Q might work. But I do know they are cast iron. I forget if they are 4 or 2 pots though.
Old Feb 9, 2005 | 01:32 PM
mzmtg's Avatar
From this page: http://importnut.net/300zxbrakeswap.htm
One good alternative to the 300zx brake swap is the hardware found on the Infinity Q45. The equipment will mount just as the 300zx's units, but will offer more wheel clearance. The Q45 front brakes are the same diameter as the 300ZX rotors but only come in a 28mm size. The main advantage to the Q45's equipment, is that it uses a 2 piston slider caliper. The pistons are located on the back side of the caliper allowing the front side to offer nearly the same wheel clearance as the 240's stock brakes.
For those interested in avoiding the purchase of new wheels or wheel spacers, the Q45 calipers are a noteworthy option to consider.
Old Feb 9, 2005 | 02:05 PM
Jeff92se's Avatar
I'm needing a caw
There you go! Done yet?
Old Feb 9, 2005 | 02:12 PM
Mizeree_X's Avatar
Jeffy, I called Z1 motorsports and inquired about their front rotor upgrade for the Z32s. It uses a 2-piece 13" rotor. Turns out it is a Cobra rotor But, he wanted $500 for a pair of them, so no lower-cost 2-piecers I've come across as of yet.
Old Feb 9, 2005 | 02:15 PM
Jeff92se's Avatar
I'm needing a caw
Yup. That is what I gathered too. But they aren't really that clear unless you ask them point blank like you did. hehe. Since the hats are custom made, I don't see why oen couldn't order them to the Nissan hub bore and stud size. They must have that program/tools as they should have 2 piece rotors for Nissans. You can't just use a Nissan hat as the offset would be wrong.
Old Feb 9, 2005 | 03:27 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Interesting....
I kind of like the LED mirrors and what looks like SplitFire ignition coils.
Old Feb 10, 2005 | 08:44 AM
Jeff92se's Avatar
I'm needing a caw
Ben, even if you have to go to 17s, this is still the best/cheapest alternative.
http://forums.maxima.org/showthread.php?t=378094
Old Feb 10, 2005 | 11:57 AM
mzmtg's Avatar
File not found?
Anyway, new wheels are not an option.
Old Feb 10, 2005 | 12:20 PM
MaDMaX024's Avatar
i've got Q45 calipers, shaved stock rotors and semi-metallic pads...pads needed to be a bit shaved but otherwise everything fits well..
Old Feb 10, 2005 | 12:32 PM
mzmtg's Avatar
More details?
Old Feb 10, 2005 | 01:18 PM
Jeff92se's Avatar
I'm needing a caw
What's to know Ben? It's the same procedure as the 300z calipers. Don't exactly know why the pads needed to be shaved though. The Q and Z calipers have the same mounting dimensions.
Old Feb 10, 2005 | 03:48 PM
«§»Craig B«§»'s Avatar
some, but not all UK maximas had the 2 piston calipers. I think it was the later models. I remember Pete saying that under normal conditions, he couldn't tell a difference between them though.
Old Feb 10, 2005 | 08:06 PM
MaDMaX024's Avatar
the mount up the same, but the rotors need to be shaved so they dont hit the caliper "body" same reason the rotors need to be shaved with Z32 calipers.
the pads need to be shaved because on the Q pads where the wear sensor is installed rubs on the center of the rotor. no big deal, 2 minutes on a bench grinder and all is well.
theres not much else to know. braking power is much better but the pedal feel leaves much to be desired.
Old Feb 11, 2005 | 05:21 AM
mzmtg's Avatar
So is it worth all the effort, or not so much?
Old Feb 11, 2005 | 08:33 AM
I30tMikeD's Avatar
I wonder which year Q45 he is refering to. Through the mid 90's they used 15" rims, I wonder if there is an option for me since I run 15" Q45 rims? Where can I find brake specs on mid 90's Q's?
Old Feb 11, 2005 | 08:38 AM
mzmtg's Avatar
He is talking about the first Gen Q, through 96. Then starting in 97, they went to a single piston caliper. I don't know what the latest version uses though.
Old Feb 11, 2005 | 08:42 AM
I30tMikeD's Avatar
Hmm, might be an option for me since I refuse to get rid of my 15's for a brake upgrade.
Old Feb 11, 2005 | 08:56 AM
mzmtg's Avatar
I haven't looked into what pads are available for those calipers yet. If there aren't any reasonably priced upgrade pads, I really dont think the mushy feel, and all the effort would be worth it all.
Old Feb 11, 2005 | 09:02 AM
Jeff92se's Avatar
I'm needing a caw
Every time someone put the 4 pots on the small rotors, most report more pedal travel. Which is logical. But most if not all who use the Cobra/2k4 rotors don't seem to report this. I would think with the Q calipers, it shouldn't affect the pedal travel nearly as much. (unless those two pistons are huge). I'm suprised that person experienced enough pedal travel to post about it. You guys should look into what the Q's MC size and shape is.
Apr 16, 2020 05:15 AM
Quickgtp
Apr 13, 2017 03:30 PM
maxfever1987
Nov 19, 2016 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
IceY2K1
47
Oct 9, 2007 09:00 PM
