DIY brake job w/ABS question
Old Feb 28, 2005 | 09:06 AM
Kevin's Avatar
Do you have to disconnect the battery if you ahve ABS ?
Old Feb 28, 2005 | 09:10 AM
Sprint's Avatar
no ..................
Old Feb 28, 2005 | 09:32 AM
dmontzsta's Avatar
Ford Only.
Old Feb 28, 2005 | 04:32 PM
MaximaPolak's Avatar
Old Feb 28, 2005 | 05:28 PM
Zero Deuce SE's Avatar
Not to change the brake pads. For bleeding the brake system, you have to either disconnect the battery ground cable or the ABS actuator connectors.
Old Feb 28, 2005 | 05:29 PM
dmontzsta's Avatar
Ford Only.
hmmm...I have never done that.
If the car is off, how does the computer know you bled the brakes?
Old Feb 28, 2005 | 05:33 PM
Sprint's Avatar
i have never had to do that either
Old Feb 28, 2005 | 05:59 PM
Ant96GLE's Avatar
i've never done either.... either
Old Feb 28, 2005 | 06:01 PM
It's in the FSM and has been for years. I have owned 3 Maxes with ABS and every FSM stated the same procedure for brake bleeding.
Old Feb 28, 2005 | 06:02 PM
Kevin's Avatar
didnt do it either for my 4th gen, my abs light has always been on from day one so i didnt even think twice about it. but I've heard from others ( bimmer forums) the same thing, for bleeding the Battery shoudl be disconnected.
Old Mar 1, 2005 | 03:05 PM
A32Matt's Avatar
with some Dodge trucks with ABS they need to use the scanner at the dealership to bleed the ABS brakes
Old Mar 1, 2005 | 05:08 PM
SkoorbMax's Avatar
I've read everywhere to discon abs actuators when bleeding brakes. When changing pads/rotors, no need.
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
boomerbrian
Sep 4, 2015 08:25 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
