Quick couple of questions about replacing CV boot or axle!
Old Mar 4, 2005 | 07:23 AM
SkoorbMax's Avatar
Read motorvate's guide. Two things:
1) Turpentine. Where do you buy it, and is it the best for cleaning a filthy joint?
2) He says almost nothing in his guide about ripping the inner end of the axle from the transmission. Does anybody have details? I saw a touch more info on raxles.com that a guy did for his Mitsubishi, but I want to do it as easily as possible without extra work for myself
Thanks! I plan on doing my 97's both outers tomorrow. This will be the biggest job I've done on either car, as most other stuff I've done has been maintenance.
Old Mar 4, 2005 | 03:18 PM
njmaxseltd's Avatar
If your boots are broken and the CV joint is filthy dirty your better off buying a new axle because your contaminated joint WILL eventually fail.
Old Mar 4, 2005 | 04:52 PM
SkoorbMax's Avatar
Yeah I've considered that, but given the massive cost savings of doing it myself (not to mention it's another notch on my belt) I'm going to give it a go like this first. One of the boot is of yet untorn, and the other tear is recent, with zero apparent damage (which I can more thoroughly check when the axle's off the car).
Old Mar 5, 2005 | 05:46 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
You're better off listening to Tom. Do you know for a fact when exactly it was torn? Probably not. You're most likely going to pay the 30 bucks for the rebuild kit, replace the boot, and have the axle fail on you in a year or two and end up spending the money anyway.
Old Mar 6, 2005 | 05:41 PM
4dscPat's Avatar
Replacing CV boots is a pain in the ***. New axles with both joints are like 60$.
Old Mar 6, 2005 | 05:57 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
just replace the whole axle. when my axle finally died, (i drove on a ripped cv boot for about 5 months) i bought a used one off an org member for $40, and he helped me install it too. that was about a year ago and its still fine.
kingw323
20
Oct 21, 2015 08:36 AM
follyburr
Aug 12, 2015 10:22 PM
classymax420
Aug 6, 2015 06:35 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
egali045
Aug 5, 2015 09:02 AM
