Just installed Stillen Y-pipe. Was much easier than i THought. Long>>
Old Oct 7, 2000 | 05:57 PM
MikeO's Avatar
Install only took 1 and half hour. Car seems to have gained more in low end than high end. So far no rattles or "bees in a can sound" (maybe because i had y-pipe ceramic coated). I found it was a lot faster to just unscrew the O2 sensors before removing stock y-pipe, so there would be no need to disconnect the wiring. I had to use special curved wrench tho due to lack of room. And I also had to remove the black bracket behind the two bolts that was holding the stock ypipe up since it was in way of new ypipe ( instructions didnt mention that).
Old Oct 7, 2000 | 07:44 PM
Bryan91SE's Avatar
I'm doing mine tomorrow --->
Any quick tips for me? How hard were the bolts to get off? Did you use liquid wrench?
Old Oct 7, 2000 | 08:23 PM
MikeO's Avatar
Yeah, soaked the bolts in WD40 for an hour before starting and
need a couple extension and a flex joint, use "long" 14mm socket.
Old Oct 7, 2000 | 08:39 PM
jasonmeter
y-pipe
How much louder is it and what type of muffler?
Old Oct 7, 2000 | 08:43 PM
MikeO's Avatar
Stock exhaust. THere was hardly any noise increase n/m
n/m
Old Oct 8, 2000 | 02:21 PM
ZuMBLe's Avatar
Re: y-pipe
After the car is warm, you won't notice the sound unless you put your ear up to the muffler. If you put your ear up to the muffler you will hear a throaty "blurble". When the car is cold you will hear the same "blurble" but louder. The car smells when you first start it up too.. Hehe.
ZuM
Old Oct 8, 2000 | 07:57 PM
Carlos A's Avatar
Ceramic Coated?, (is it really or it is Mild Steel...)
with chrome?,
I just bought one (and would you believe it, I had no time so far to installe it?.) It is mild steel (even though the add in the net says stainless steel,) chromed.
I have never heard of the ceramis coated one. Would this one resist the winter better.
Carlos
Old Oct 9, 2000 | 12:08 AM
MikeO's Avatar
Well it comes chrome plated but I had mine recoated with ceramic coat. since>
Since it was rusty when it came out the box. Another tip for those with Stillen y-pipe. Dremel off that oval plaque that states "for off-road use only". It is a good place for corrosion to start. Especially since there is alsolutely no coating behind it. And the gap behind it will trap dirt and road salt.
Old Oct 9, 2000 | 10:00 PM
Carlos A's Avatar
Re: Well it comes chrome plated but I had mine recoated with ceramic coat. since>
Thanks,
How much for the ceramic coating?. Who would do that?, or where can I take my pipe for that? (I live in Rochester NY).
Thanks,
Old Oct 9, 2000 | 11:36 PM
MikeO's Avatar
I don't know any ceramic coating place in N.Y. But you could try these places >
http://www.hpcoatings.com
http://www.bc-engr.com
http://www.performancecoatings.com
I'm from Vancouver B.C. so I had mine done locally. Another place is http://www.jethotcoatings.com/. But I have heard a few people complain about their coatings not lasting.
Old Oct 9, 2000 | 11:55 PM
MikeO's Avatar
Another place>>
http://www.amr-coatings.com/index.html
Old Oct 10, 2000 | 05:43 AM
BEJAY1's Avatar
Conecarver
Y-pipe install help
Got my Y-pipe w/o any gaskets. Any suggestings what to ask for? Rings? Crush? Gaskets? Sizes? Connecting to an RT Cat with the swivel flanges. (Not gonna replace those yet)
Old Oct 10, 2000 | 06:22 AM
breaux124's Avatar
Where do you guys recommend getting the Y-Pipe and what was the cost?
Old Oct 10, 2000 | 04:04 PM
BEJAY1's Avatar
Conecarver
If you want the Catman SS Y-pipe then go for the $400 group deal here on maxima.org. Otherwise if price then try the Stillen through a local shop. s/b $300-$325
Old Oct 10, 2000 | 04:08 PM
MaineI30's Avatar
I got very UNlucky. Mine was much, much, much, much harder than I thought. Soo many hitches/problems. But worth it.
/aac
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
Samedi
Sep 3, 2015 01:07 PM
maximusrising
Sep 2, 2015 09:55 AM
