Walbro 255 Fuel Pump Problem.. Fuel Pump filter fell off pump
Old Mar 18, 2005 | 08:57 PM
95CustomMaxima's Avatar
I recently put in a GSS 342 Walbro 255 Fuel Pump and ran into a slight problem with the filter that connects to the pump not wanting to stay on.. If you know what I am talking about, there is a "nipple" on the pump that the "filter/screen" connects to.. Well the connection at the point was not very good.
Tonight I was almost on Empty, so I filled up my car with gas and after about 10 seconds of diving the car started jerking really bad, no power and it died about 15 seconds later.. I then could not get the car to start and right then I knew it was a fuel problem, which immediately led me to believe that is what happened and sure enough I was right. I pulled the pump and looked in the tank to see the filter sitting in there disconnected.
Has anyone ran into this problem? Or anyone have any ideas on how to make a better connection? Any help is appreciated
Thanks,
-Nick
Old Mar 18, 2005 | 09:40 PM
Nealoc187's Avatar
SLOW
Did you use the little washer provided with the walbro, or reuse the stock washer. I'm referring to the washer that holds the pickup onto the nipple.
Old Mar 19, 2005 | 06:02 AM
I am not sure I know what you are talking about. I reused all stock items from the stock pump.. Only thing new is the actual fuel pump itself. I did not recieve anything besides the pump when I got it. I am going to make some calls to automotive stores around and see if I can get a new filter for the pump.
-Nick
Old Mar 19, 2005 | 07:50 AM
Nealoc187's Avatar
SLOW
Well there is a little plastic tube (the fuel pickup) that is on your stock pump, it attaches with a little clip washer to the pump and has the rectangular screen on the end of it to keep debris out of the pump. The walbro pump comes with one that is the incorrect shape for our fuel tank, so you have to take the tube off the stock pump and attach it to the walbro. It is the only thing there is that can fall off the pump so that has to be what you are talking about. My question is did you attach it yourself using the clip on the stock pump, or did you use the screen/tube/washer that came with the walbro.
Old Mar 19, 2005 | 07:51 AM
Nealoc187's Avatar
SLOW
Take a picture of what you are talking about if you can and I will try to help you. I just did a fuel pump last week so it's fresh in my mind.
Old Mar 19, 2005 | 09:28 PM
Neal thanks for the help. I did reuse my stock one, and it fell off. I made it work though by taking a soldering iron and "welding" a little bead around the tube. I know can hold the pump by the filter without any issues. While I was at it, I decided to put a Z32 fuel filter in. But once again I appreciate your help Neal.
Thanks,
-Nick
Old Mar 19, 2005 | 09:30 PM
*By welding I mean melting a little bead around the tube
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
