Gtech Pro meter
Old Mar 22, 2005 | 11:37 AM
Kta920's Avatar
Gtech Pro meter
Anyone use the Gtech Pro Competition Meter on their car? I just bought one (RR Model) and I used it in my friend's STOCK GTP and it read that he ran 376hp. Then we did it in my friend's V6 Mustang (has exhaust) and it read 280hp. I know these stats aren't even close to right,so is this thing a piece of ****? Or am I using it wrong?
Old Mar 22, 2005 | 01:49 PM
Nismo87SE's Avatar
What kind of weight did you put in for those cars? Also was the road that they were tested on flat? Was the gear ratio input correct as well. If not then its no wonder the results were off.
Old Mar 22, 2005 | 03:12 PM
stevay's Avatar
i've never used one of these before but everything needs to be exact...weight etc.
Old Mar 22, 2005 | 05:45 PM
ManualMaxima's Avatar
5th Gen till she dies!
also remeber the point of the g-tech is not to give perfect acuarate data but to more so show improvments after mods....it will not be 100% correct but like everyone eles said make sure all your info is correctly added into it and the run is done on a flat surface.
Old Mar 22, 2005 | 06:44 PM
z32drifter's Avatar
yeah sounds like the weight was entered incorrectly.... if you enter more weight than the car hp will go up
Old Mar 22, 2005 | 06:49 PM
SR20DEN's Avatar
VQ Wizard
The Gtech Pro Comp. should be somewhat accurate when setup correctly. It's far more advabced than the old Gtech Pro.
376hp for a stock GTP is not even in the correct galaxy. Try setting it up better next time. Take the car to a weigh station to get correct vehicle weight.
Old Mar 23, 2005 | 03:51 PM
Kta920's Avatar
I just took the weight in the door jams.We were only doing it quick,but I figured it would come out a little more accurate.Yes the road was completely flat,I did all the calibrations,and entered the weight on the door jam,entered the redline,and it told me to rev the engine to 4500rpms,then to 2000rpms.Shouldnt be too far off.
Old Mar 23, 2005 | 04:02 PM
Zack342's Avatar
that is not the weight of the car on the door jam.....
Old Mar 23, 2005 | 09:22 PM
NmexMAX's Avatar
dot dot dot ...
Haha no wonder you got those radings. 4k+
For a reasonable estimate, look at your registration card.
spencerwh1
Jun 30, 2016 05:44 AM
bryants95max
Oct 2, 2015 12:52 PM
ivorton23
Sep 28, 2015 09:08 PM
Spartan1310
Sep 28, 2015 08:03 AM
Socalstillen
Sep 26, 2015 12:01 PM
