Adventures in weight reduction part II (pics)
Old Apr 12, 2005 | 07:04 AM
  #41
plurco's Avatar
Originally Posted by nismos14
instead of running that exhaust to the side why not just cut it as close to the y pipe as possible then use just a resonator there and nothing else. also im sure you got all of the under-carriage stuff like the heat shields and what not, if not, there's another idea
I have removed alot of the undercarriage stuff, and this week I am putting it on the rack ad geting everything else.
Old Apr 12, 2005 | 07:26 AM
  #42
plurco's Avatar
man I just remembered. I have 3/4 a tank of gas in the car. My gas gauge does not work anymore so I forgot about that. I am looking forward to getting my fuel cell. I get that will be good for 40-50lbs.
Old Apr 12, 2005 | 08:43 AM
  #43
liqidvenom's Avatar
brotherhood of tq
what do u drive as ur everyday car?
Old Apr 12, 2005 | 08:57 AM
  #44
plurco's Avatar
2002.5 Jetta GLI 1.8T
Old Apr 12, 2005 | 10:07 AM
  #45
2 Da Max's Avatar
oo 1.8t huh, i still love the old MK3 vr6s oo those cars are fast
Old Apr 12, 2005 | 10:08 AM
  #46
Broaner's Avatar
2060lbs and falling...
Ending the exhaust in the tunnel doesn't work very well. I'm currently doing this and having trouble with it heating the lines. The actual tank isn't getting too hot. Its just the lines. During extended WOT runs it heats the lines and causes a vapor lock. The ECU sees that the engine isn't getting fuel and tells the pump to send more. The pump does so but it just gets vapor locked again. This cycle happens several times until the current to the pump gets so high that it blows the fuse. This has happened to me once. Although putting a simple 90 degree 2.5" bend right off the muffler will solve all this problem.
Old Apr 12, 2005 | 10:16 AM
  #47
plurco's Avatar
I have had no trouble with the way I have my exhaust. Sounds good, looks cool, and seems to do the trick performance wise. I will get some pics of the undercar this week.
Old Apr 12, 2005 | 10:38 AM
  #48
Broaner's Avatar
Is your ending after the stock resonator? That is probably why you're fine. My muffler is ending 14 inches from the gas tank and about 10 inches from the fuel lines.
Old Apr 12, 2005 | 10:40 AM
  #49
plurco's Avatar
it makes a right hand right before the gaas tank and exits the passenger side.
Old Apr 13, 2005 | 10:59 AM
  #50
Ceasars Chariot's Avatar
Old Maxima Legend
how many gallons of gas does a fuel cell hold ? 40-50 lbs, sounds like a great WR mod, where do i sign ?
Old Apr 13, 2005 | 11:40 AM
  #51
plurco's Avatar
I have a 5 gal. fuel cell. you can get bigger. I will be sure to inform everyone on the exact weight reduction.
MaximaGuy14
Aug 30, 2015 05:39 PM
max_speed97
Aug 26, 2015 07:46 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
