Very Dissapointed at the Track Tonight
Old May 12, 2001 | 12:47 AM
Jeff91SE's Avatar
Long story short because its late. 3 runs.
1st - 60': 2.577 1/4: 17.261 @ 81.12
2nd - 1/4: 17.3
3rd - 1/4: 17.1
Dont have all the info for last 2 runs because theyre computer messed up, sorry. I bogged the first 2 runs; launched about 2500rpms. 3rd run I hit it at like 3500rpms.
Needless to say Im not happy with these times. Not sure what the problem was. Maybe it was because Id never raced a 5speed up at a track, or the exhaust leak or hot engine. But whatever, its mainly my fault.
I ran 17.1 in my old '95 Z26. I know my Max is faster than that car.
Questions, comments, concerns very welcome.
Old May 12, 2001 | 12:36 PM
Nismo87SE's Avatar
We need more info
Since your timeslips didn't come out right I suggest trying again. But from your first run I can tell that your launch is too soft. Also which track do you run at, is it at or close to sea level? What rpm were you shifting at and do you finish in 3rd or 4th gear? I believe you should be shifting around 6200rpm for 1-2, 6000 for 2-3 and leave it in 3rd gear to the finish. Ideally you want your 60ft times to be in the 2.0-2.2 range for good ET's.
Old May 12, 2001 | 12:52 PM
Sprint's Avatar
I usually launch at 4000 rpm and ride the clutch out a bit...
2nd - 1/4: 17.3
3rd - 1/4: 17.1
Old May 12, 2001 | 04:05 PM
bullseye's Avatar
Re: We need more info
I'm not sure what his stock wheel/tire sizes are, nor what his gearing is like, but he may have to shift into 4th to avoid exceeding redline. With stock rims/tires, I could end the race in 3rd, but my engine was screaming, and well past its torque peak. If I shifted into 4th before the finish, the engine fell below its torque peak. Neither method was optimal for me.
Recently, I switched to a smaller drag wheel/tire combo for the front, effectively yielding lower gearing, and allowing me to upshift sooner at every gear change. I shift into 4th about 150' before the finish line nowadays, which gives the engine a chance to PULL nicely through the trap.
Old May 12, 2001 | 04:38 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Re: We need more info
with a stock VG motor there is now way he's gonna top 3rd out in the 1/4
Old May 12, 2001 | 04:44 PM
LoveSick's Avatar
So are you concern about your driving skill or your car's performance? BTW, you can't expect to run low 16s with your 91 for a 2k Maxima SE with differential runs at high 14.
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
TxBroncosFan
Sep 21, 2015 06:54 PM
