old gas, where to get rid of it.
Old May 3, 2005 | 07:07 AM
PRPmax's Avatar
I just got another car. This car has been sitting for almost 1 1/2 with a full tank of gas. I need to get rid of it since it wasn't been treated. I can get the fuel out the car. but,where would I get rid of 10 to 14 gallons of gas?
Old May 3, 2005 | 07:22 AM
tavarish's Avatar
fwd gone rwd cr00
the kitchen sink...
maybe you should just drive around, then clean the fuel injectors and filter.
Old May 3, 2005 | 08:25 AM
Bobo's Avatar
How long has it been sitting - a month and a half or a year and a half? If its only a month and a half, I wouldn't worry about it. Just dilute the existing gas from time to time when it gets down 1/4 or 1/3 of a tank and don't take it below 1/4 for awhile.
When was the fuel filter last changed? They should be replaced every 30K.
Old May 3, 2005 | 09:26 AM
Y2KMaxGXE-R's Avatar
Does the car run? I would add nothing but a bottle of octane booster in the gas tank...
Old May 3, 2005 | 09:36 AM
MrEous's Avatar
^ Jeff™
Bonfire...?
hides in fear nobody thinks he's kidding...
Old May 3, 2005 | 09:59 AM
ColdSHO's Avatar
drain it and sell it cheap to someone with a pos car that doesnt care, thats what i did.
Old May 3, 2005 | 10:07 AM
TXT-1's Avatar
My local Pep Boys excepts old chemical waste like motor oil and gasoline. You may want to check that out in your area.
Old May 3, 2005 | 10:37 AM
njmaxseltd's Avatar
A full tank of fresh clean gas can sit for a long time without going bad. It's when it sits with very little gas in the tank that it tends to turn to varnish and go bad. You should be fine, just start the car and dump a bottle of Techron in the tank.
Old May 3, 2005 | 11:07 AM
Whitemax's Avatar
Disco Biscuit
Lots of 2 liter soda bottles and alot of matches.......
Old May 3, 2005 | 11:31 AM
C MAX's Avatar
buy a gallon of pepsi and get your drink on.
Old May 3, 2005 | 11:53 AM
maximazation's Avatar
put in a HUGE bottle and put a match to it....instantly it'll be gone..jk
i think you can dispose of it the way you dispose motor oil and anti-freeze.
Old May 3, 2005 | 12:08 PM
Matt93SE's Avatar
STFU n00b!
as long as the tank is sealed properly, it's usually not that bad of shape.
I bought a car a while back that had a 1/4 tank of gas sitting in it for almost 2 years.. swapped engines in it (reason it was parked was blown engine), and the thing fired right up when I turned the key.. no problems with the gas.
just drive the sucker to a gas station.. when you get there, fill the tank the rest of the way up with 93 octane and keep driving. no problems usually.
Old May 3, 2005 | 05:04 PM
PRPmax's Avatar
a year and half. not a month and half.
Old May 4, 2005 | 06:57 AM
tubs's Avatar
i would not think it would cause a problem...but i second the bonfire idea...
Old May 4, 2005 | 10:04 AM
Broaner's Avatar
2060lbs and falling...
Siphon it out and let it evaporate.
Old May 4, 2005 | 10:20 AM
passEMonTHErite's Avatar
Same place you would put used motor oil....
down the sewer.
Old May 4, 2005 | 10:31 AM
Broaner's Avatar
Or keep it in some five gallon buckets and use it as a cleaner.
Old May 5, 2005 | 10:51 AM
maxgtr2000's Avatar
KH3 by popular demand
Siphone it out a gallon at a time and take it to Wolly world, they should be able to dispose of it. You could use a gallon at a time in another vehicle to just burn it off.
Old May 5, 2005 | 10:57 AM
MDeezy's Avatar
I agree to fill up the rest of the tank and go for a long drive, stretch her legs a bit. Or if you'd like I'll be up there in atlanta tommorow I'll take the gas off your hands, especially with these gas prices. . . .
Old May 5, 2005 | 11:33 AM
Magikone69's Avatar
drain it, store it, use it in your lawn mower lol.
wingnut2006
Sep 19, 2015 06:13 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
Maxboy23
Sep 9, 2015 10:37 AM
dcam0326
Sep 7, 2015 07:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
