*UPDATED* Oil and ATF Analysis Spreadsheet -->
Old Apr 26, 2001 | 10:09 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
After the continued successful brainwashing by the media that if a car goes one mile over 3k on the same oil it is going to die, Shing, myself, and Jeff92se decided to start getting our oil analyzed at the end of each oil interval to see if "3k is a waste of money".
In the spreadsheet at the bottom of my sig (finally linked through Clubmaxima.com in ZIP format....thanks Peel!). Just right click and save to your disk and extract for your viewing pleasure.
http://forums.clubmaxima.com/files/1...%20Results.zip
The motor oil of 5 cars are analyzed:
Shing's 98 Maxima (twice so far)
Both were around 8k intervals with Mobile 1 oil and Nissan filter
My 99 Maxima
One analysis after 10.4k with ULX-110 (dino oil with a LOT of additives) and Mobil 1 filter
Another analysis after only 1,288 miles on Amsoil with an Amsoil filter just to see the types of additives used compared to ULX-110.
My 94 Maxima
One analysis after 8.5k with ULX-110 and Mobil 1 filter
My dad's 99 Acura TL
One analysis after 12k with Amsoil and Amsoil oil filter
Jeff92se's Maxima
One analysis after 6k with Amsoil and Toyota filter; Jeff has been having coolant loss and oil consumption problems.
All other cars besides Jeff's go high mileage (15k plus per year) and do not have oil consumption problems.
The results speak for themselves. Except for Jeff's Max, all other cars went extended drain intervals with normal wear levels.
Other interesting things that an oil analysis can bring to light:
-- Wife 2.0's 99 Maxima has some sort of air filter problem. Whether it's a leak somewhere or was just a dirty filter is/was unknown. That second sample at 1,288 miles had a high silicon content already, which means dirt is getting by the air filter somehow. No solution yet, but good to know there was an issue with it.
-- Dad's 99 TL had a lot of bearing wear, which is apparently typical of Honda motors (which I didn't know). Also, the K&N air filter hadn't been cleaned in 11k, so it was good to know that a K&N drop-in filter does its job.
-- Shing puts WAY too many miles on his car. He already has another Mobile 1 sample he is sending in with 11k on it. This spreadsheet will be updated when those results are available.
As for the ATF results, it is still a work in progress as well:
-- Nissan ATF lasts NO MORE than 30k. My 99 was tested with 32k on it and it needs replacement.
As for my 94, I'm experimenting. I had my ATF examined after 30k (when I had a flush done by a machine) and it needed replacing as well. I then did 3 drain 'n fills, refilling with Amsoil synthetic instead of plain dino ATF. On the 4th drain n' fill, I took another sample and should have ALL those results on the spreadsheet by next week.
In addition, I am sending off my auto tranny fluid to be analyzed this week (after 30k) and will post those results as well.
In conclusion,
3k is a waste of money.
Old Apr 26, 2001 | 01:35 PM
1MAX2NV's Avatar
Good Stuff Bill!!!
Good thing I flushed the ATF around 28K. I'm just going to flush the tranny every year. I put about 20k a year. I have some Redline D4 in the tranny right now. I might switch to Mobil 1 or Amsoil. Redline is way too expensive.
Old Apr 26, 2001 | 02:29 PM
bill99gxe's Avatar
Originally posted by 1MAX2NV
Good Stuff Bill!!!
Thanks Tony!
Amsoil ain't cheap either, as one 2-1/2 gallon container plus a couple of qts. will run you $75 or $80 after tax/shipping/various fees/blah/blah/blah....
I would probably just go Mobile 1 ATF.......the yearly replacement wouldn't be a bad scenario with Mobile 1 ATF for your kind of mileage.....
Old Apr 26, 2001 | 04:44 PM
SunMax's Avatar
Thanks Bill.
Your result will definitely make me get my act to change my ATF. I had been pushing it back because of busy schedule.
Thanks again!
Old Apr 26, 2001 | 05:44 PM
demian's Avatar
is there a particular ATF weight that you should use? or is it just one uniform ATF?
Is Mobil 1 ATF available at any parts store? thanks.
Old Apr 26, 2001 | 07:14 PM
brubenstein's Avatar
Most people, particularly here, match the profile for "severe maintenance schedule", and that calls for 30k ATF refill. I think a complete flush and change to synthetic, and then a pan dump and refill once a year. Is a reasonable routine.
As to the question about weights of ATF, there aren't any. There are, however, several different types of ATF. Nissan calls for Dexron III fluid. This is good, because I think synthetic is only available for this type of fluid. Mobil 1, synthetic is the right type, and is sold in most places.
Old Apr 27, 2001 | 05:24 AM
bill99gxe's Avatar
Answers
As brubenstein said, Nissan uses Dexron III which synthetic ATFs usually are.
I know for sure Mobil 1 ATF is available at AutoZone and I'm pretty sure it's available at most Advance Auto Parts stores. I can't remeber the price......It's $6 or $7 quart I think.....
As for 30k only applying to "severe maintenance schedule".....if driving the Max everyday to and from work and going on a few trips a year constitutes severe driving, then everyone with slushboxes should be replacing Nissan ATF every 30k. As for how much longer synthetics go: Amsoil ATF claims 3 times the normal service life of ATF, which translates to 90k. I would speculate that any synthetic should go at least 60k, while conventional ATF shouldn't go more than 30k.
IMHO, if you drive in REALLY dusty or harsh climate conditions or race your Max frequently, then conventional ATF probably loses its effectiveness after 15k. That's only speculation, though, but I have seen other cars that follow that kind of interval for replacement.....
Old Apr 27, 2001 | 05:37 AM
Re: Answers
That's the point: everyone should. The heat related damages to the transmission are cummulative. You don't have to sit in bumper-to-bumper traffic or drive up a long grade, in the summer, with the AC on for very long, for the fluid temp to get very, very high. You'll also feel the transmission work better, besides longer. The price of annual 3 qt refills are so cheap compared to the price of a new/rebuilt transmission, that it doesn't make sense not to.
Old Apr 27, 2001 | 08:11 AM
walsh03's Avatar
good info
Bill, thanks for the great info. Real good stuff. Yuo da man.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
