Overdrive
it works when used in the right spot. you dont want to run it all the time. youll wear out the power band in 3rd gear plus your gas mileage goes down the sh!tter. leave it on for even a little bit and youll see how much gas you burn. flippin it when going to pass someone on the highway or something like that is when it comes in handy. i usually dont bother tho. just stomp on it, she'll get movin
Originally Posted by DJ2Max
so with a 5.5 gen i should be driving with it on 3 if i want to save on gas? will it hurt the tranny to shift it to d while im on the highway going 60+?
Originally Posted by konak85
Put it on during highway speeds, leave it off in city speeds. SIMPLE
I say, if it wants to shift into 4th, and save me some gas $$$, then it can go right ahead and do so!
OD simply means 4th gear. some say always driving with OD is bad for the tranny (but it only goes to 4th gear if it gets high enough.) it's bad for those that drive hard and brake a lot causing it to shift back and forth excessively. there you would be better limiting it to 3 gears.
best to always use OD unless you decide to drive like above or you want to stay in low gears due to snow or steep declines.
For awhile (last car) I drove in D then only OD if on the highway like someone suggested. but I found myself forgetting and staying in D (3rd) while on the highway
I feel that is worse then the possibility of hitting 4th gear in the city momentarily b/c you always use OD.
MarcJD
Jan 19, 2005 11:32 PM
But yea, I usually don't mess with it. The 5th gens have that OD button, the 5.5s is just a matter of switching from 3 to D. I always leave mine in D when driving.
