Boosted Maximas please check in.
Old Jun 7, 2005 | 06:58 AM
dmontzsta's Avatar
Ford Only.
Please post your year, type of boost, psi you are running, hp and any other info you might have. I am having a disagreement and need to show some proof, seems people do not believe the Maxima can run on 10-12psi on 91 octane, people are calling it "overkill" and saying it could only do that in "spurts". Please check in.
Old Jun 7, 2005 | 07:02 AM
|Bijan|'s Avatar
UCF Lexus
NOT boosted but;
10-12 is NOT overkill. Its a high amount, but not extreme. I know of 1 turbo max that would spike to 14psi - and another one that was dynoed at 16psi.
As long as it's TUNED right, there really shouldnt be too many issues. The air/fuel mixutre is what determines the life of the motor
Old Jun 7, 2005 | 07:05 AM
Deckdout2's Avatar
Play with my balls
http://norcal.maxima.org/showthread.php?t=360493
This might be the best place to find that.
Old Jun 7, 2005 | 07:11 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
*cough*theresalreadyagoodlistintheforcedinductionf orum*cough* j/k don
Old Jun 7, 2005 | 09:09 AM
ramberg's Avatar
GrandPa
Nice tread. To bad they don't have SC's or TC's for the 6th Gen. I am running about 310 hp at the crank. Injen CIA, Racing Pulley and Greddy SP-2 Cat-Back System. I just had a CE Y-Pipe installed and will have it dynoed when I come back from my drive to Florida. Later Warren
Old Jun 7, 2005 | 09:12 AM
I30tMikeD's Avatar
With the right fuel management 10-12 psi is not that big of a deal, as far as what the motor can handle. You could blow a motor on 5psi, it is how you have it tuned. I would be more worried about the tranny on a 12lb boosted maxima and the motor.
I would agree that 91 octane is not ideal, but with some timing retard it is fine. I don't think I would want to run 12lbs of boost on a hot day with stock timing and 91 octane.
Then there is the difference between 12psi on a turbo maxima and 12psi on a SC maxima. You can get away with alot less with the SC. [B]In general[B] 12 psi on a SC max is worth 325-350 hp and about 250-275 torque. 12psi on a turbo maxima, in general is more like 350-400 hp and 350-375 torque. So the question needs to be more specific as to what type of boost your refering to.
Old Jun 7, 2005 | 10:38 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
97 - T4/T04E 60 trim/ ball bearing.
Previously ran 12 psi street, 14-16 when I got greedy @ 91-93 octane.
Old Jun 7, 2005 | 10:41 AM
Jeff92se's Avatar
I'm needing a caw
Donald. 1st of all, use the correction section. 2ndly, you KNOW there are guys running 10+ psi on pump gas. Research and you will find it.
Finkle
Sep 27, 2015 09:53 PM
cheftoo
Aug 20, 2015 05:17 AM
Mcnabb34
Aug 11, 2015 08:45 PM
kirkhilles
Aug 8, 2015 10:53 AM
