Painting Spark Plug Cover
I want to paint the spark plug cover on my engine (commonly misreferred to as the valve cover). You know, the part that says NISSAN 3000 V6, all that good stuff on it. Anyways, I have a few simple questions regarding painting it:
-I should be sanding it before painting it right? What kind of sandpaper should I use? (like what grit)
-What kind of paint should I be using? Just high-temp. engine paint?
-What can I do to prevent the NISSAN letters from being painted? (I want to leave them silver) I need some way of covering up just the letters, along with the row that says 3000 V6 24 Valve on it.
I plan on painting it a flat black color. I just need a way of leaving that strip towards the bottom the stock color and I want the NISSAN to remain unpainted so it's silver.
You dont need sandpaper, just use a scotchbrite pad and scuff it up. I used high heat engine paint to paint mine. To cover up the NISSAN, you can either cut out tape or you can dab on some vaseline and then wipe it off when the paint is dry. For the row with the V6, just tape that off completly. Make sure you take your time with the prep to make it look good
Originally Posted by 86maxima96
post pics when done!
One last question guys, is it just those three or four little screws that I need allen keys for to get the cover off? Or is there something else holding it down, too?
Just put the first coat of paint on...the vaseline (well I just used some generic petroleum jelly) seems to be working alright. Just need something to scrape it off after the paint dries that won't scratch the plastic.
We'll see how this turns out...
i just finished mine last night. the single pic of it drying is in this thread
http://forums.maxima.org/showthread.php?t=411186
i simply washed it, dried it very well, over night if possible, taped off w/e i wanted, n let the paint rip. the coats depends on ur methong of spray. i did about 4-6 on mine and about 2-3 of clear on top. after it all cured i lightly wetsanded to make is smooth. the previous pic is not of it complete. ill get u guys one in the morning.
Originally Posted by BlackCat
I'm thinking of refinishing it. So would scotchbrite do the trick in taking off the old paint?
homewrecker
Sep 23, 2015 03:41 AM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
