Those with Big Brake Kits, notice a loss in acceleration?
For those with BBKs- AP, Cobra/Z, or other kits with 12-13" rotors, have you noticed any loss of power & acceleration due to the larger, heavier rotors? If so, is it very noticable?
I noticed that it canceled out what the UDP did for my acceleration, so I'm back to where I was before the UDP. The brakes are in preparation for something alot faster than what's in the engine bay now.
Originally Posted by Pervis Anathema
Would you mind posting your dyno sheets and timeslips for comparison purposes?
I have none to post, sorry. My car is too slow and has too many miles to go to the track or get dynoed.
After installing my 2k4 rotor BBK (w/Blehmco relocation brackets) my car seemed (and tested) out to be much slower. We are talking about 6-7 lbs more per rotor compared to the stock 2k1 rotors so the amount of rotational mass on your front end is much greater than prior to having the kit on. Let's put it this way, took the car to the track and run the same times stock w/intake as I did with the 2k4 rotors w/SS ypipe and test pipe.
Originally Posted by vortechpower
Is there a specific willwood kit for the maxima?? If so, how much $$ does it go for and where can I find it?? thanks
Unless you opt for some really expensive 2-pc rotors, any bbk rotor will be heavier. Why do you think bbk rotors don't warp and stop better?
Question that should be asked. Do they reduce accerlation any more than a heavy set of cheap wheels do. I'd say no. Because a heavy wheel, puts more of it's mass alot further away from the center of the wheel than a heavier rotor would.
That's why I have forged 18" 350z Track editions.
OEM size Stillen rotors 15lbs +/-0.5lb and the AP 1-piece rotors were 22lbs +/- 0.5lb per my Wallymart bathroom digital 0.5lb increment scale.
Haven't installed them, so I can't say how much slower I am.
Q45 brakes install
I installed a set of twin piston calipers and roters from a junked Q on my 94se
and the weght of the rotors did not feel much more, but it realy improved stopping distance way more then before and best part only cost me 30 bucks for evrything
I have 04 Maxima IROTORS with Blehmco caliper brackets and TTZ calipers, I warped the rotors a few times now. I also do not like the way my rear brakes do not do ANYTHING. Stopping from verrrry high speeds sucks, especially when turning the rear end gets very loose. Personally with TTZ calipers and Hawk pads, my OEM calipers and rotors with Hawks performed much better. I can't justiffy the BLING when it slows me down ! IRotors for 04 Max are 24lbs each.
the rear end will get loose when you're using rear brakes while entering a turn. add more front brake (or decrease the rear), and the oversteer during trail-braking will get better.
As for weight of the rotors, it depens on what setup you have.
I've used everything from OE to 2pc racing rotors to the 2004 rotors on my car and notice very little difference in acceleration- whether I'm using my 15lb track wheels or my 26lb street wheels.
You *might* see it at the dragstrip, but elsewhere it isn't going to make a difference.. and taking a FWD sedan to the dragstrip is about as fun as listening to my wife b!tch about how much money I've thrown into this car.
I noticed the difference with the larger rotors right away- we are talking extra 10lbs at each front corner here ! I'm very picky when it comes down to power and I can deff feel a difference with OEM brakes being put back on- car deffinitaly accelerates better.
I actually love oversteer, I've lived with a oversteer happy B13 for years- all it needed was punching the go pedal and it would just pull itself out of any "drift". Maxima on the other hand feels like the rear end is just not doing anything, when traveling with 4 people on board I can litterally feel the rear brakes not working and the front end is doing everything- this is when the front rotors warp very quickly also. Since installing the BBK I have put on about 30K miles on it and my rear brakes look like they never engaged, and since I use my parking brake all the time I know both calipers do work. If I never used the parking brake I bet my rear calipers woulda been frozen by now.
Eighter way, my brake kit is for sale in the classifieds section. I like my stock brakes when paired with Hawk pads, even on a track I have no issues with em.
Finkle
09-27-2015 10:53 PM
Cant_Get_Ryte
08-28-2015 07:41 AM
MAXSE5SPD
08-23-2015 01:06 PM
MaximaDrvr
08-19-2015 09:20 PM
