Switching to Neutral Gear when Braking in an Automatic Good/Bad?
Old Jul 14, 2005 | 05:36 PM
Xservice0183's Avatar
So my brakes squeal and are otherwise pretty pathetic generic pads. I was wondering, since I got a heavy foot, someone told me they do it all the time. For those of you who want to be sure about the question, I'm asking whether it's a good idea (in terms of preserving my overall car) to shift to Neutral whenever I'm going to brake hard (or soft, give me as many views as you like). Does this actually have any affect (positive or negative), and someone did suggest this, but i'm always iffy about radical ideas...
Old Jul 14, 2005 | 05:47 PM
godlyone's Avatar
ahhh! cliMAX!
in an automatic.. i think going to drive/nuetral all the time will ruin the tranny..
in manual.. what you described is exactly what we do ..
Old Jul 14, 2005 | 06:21 PM
Drivin Maxima's Avatar
in an auto...........yeah its bad........also, its not a good idea cause when the car is in neutral, its just a big mass of metal and whatnot that will react to gravity. If your goin say 55 and have to stop suddenly and pop it into neutral, then the car is just gonna wanna keep goin, with nuttin ither then brakes to stop it. If you think physics a lil here, a body in motion tends to stay in motion unless its acted against. If your still in drive, then the natural workings of the engine of wanting to return to idle will actually help you slow down. Its kinda like gearing down a manual when slowing down.
basically think of it like this......when your drivin and your just cruisin at a constant speed......in drive Im assuming.........when you take your foot off of the gas the car slows itself down right??? Try to cruise at a constant speed and pop it into neutral, the car will coast a lot further before slowing itself down.
Old Jul 14, 2005 | 07:32 PM
SkoorbMax's Avatar
True, but since traction is finite, you can either max it out with engine braking + brakes, or brakes alone, so the end result is the same stopping power whether you use engine braking or hammer on the ABS anyway.
I would not do the neutral shifting though. People with autos should come to terms with the fact that it's not a manual; just let it do what it wants to do.
Old Jul 14, 2005 | 07:55 PM
chenzarino's Avatar
actually most people downshift with a manual.
shifting to neutral gives you less traction and will do nothing but harm to an automatic trans.
Old Jul 14, 2005 | 08:08 PM
godlyone's Avatar
ahhh! cliMAX!
no.. most people go into neutral and use the brakes..
downshifting is an extra wear on the clutch and is not as smooth...
so you are coming to a red light.. what would you downshift to?
you need to come to a stop.. so at most.. you would downshift to 2nd.. then to neutral and stop.. no point.
Old Jul 14, 2005 | 08:11 PM
MaxHijau's Avatar
I concur
Old Jul 14, 2005 | 08:19 PM
E-CARP's Avatar
I have a problem with any driver putting any car in neutral while braking. First an auto is not to be towed, and putting it in neutral is the same as towing it at 55, or whatever speed. A manual trans should be left in gear to below 15mph, and preferably downshifted to use all the engine braking you can to prolong the life of the brakes.
Just as an aside, my wife had the bad habit of de-clutching from any speed when braking, and one time we were on an interstate in a VW camper, 4 speed, and the wife says "the car won't slow down", and I said the return spring had broken, as the gas pedal was on the floor,so she procedes to declutch, and the engine went to 10,000 rpm before I got to the ignition switch! Needless to say the engine needed all new pushrods, etc. Earl
Old Jul 14, 2005 | 08:20 PM
VIP Maxima
drive an automatic the way it was meant to be driven, in D
Old Jul 14, 2005 | 08:25 PM
sean05's Avatar
I downshift the car to help save the brakes. Im bad enough with the brakes i dont need to use them anymore.. Its all personal preference.
Old Jul 15, 2005 | 12:55 AM
Brushedpewter's Avatar
Some of you don't even know how to drive. Most people I see on the street what they do is as soon as the green hits they try to hurry to the next light which is red, then they brake like hell to stop. The only time I'd put the car in neutral is if I'm going down a hill which I know of and has a lot of braking distance. I went down from a hill that goes 2.5 miles. I had the car in neutral all the way down, it was like a rolling ball, no resistance whatsoever. When I was in the clear and could see 1 mile down straight i let go off the brakes and it got to 85mph in neutral. Never pressed the gas once.
Old Jul 15, 2005 | 03:50 AM
njmaxseltd's Avatar
Brakes are much cheaper to replace then your clutch.
Old Jul 15, 2005 | 04:19 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Sounds like someone is on a good path to expensive transmission work. Drive an Auto in D, popping it into neutral will actually make your brakes work harder to get your vehicle to stop, thus leaving you with a situation where you'll eventually have to find a shop that services both brakes and transmissions.
Who's the MORON who is teaching you this $hit...
Old Jul 15, 2005 | 04:25 AM
chernmax's Avatar
If this is what new young drivers are doing, I will solicit car manufactures to put the auto shifter back on the column so people will stop playing with it...
Old Jul 15, 2005 | 05:38 AM
2 Da Max's Avatar
werd. i have a bad habbit as doing this as well.
but what i do is, when the car is at a complete stop at a light, i then put it in nuetral so i could rest my foot off the brakes? is that bad for an auto as well or no?
Old Jul 15, 2005 | 06:10 AM
chernmax's Avatar
just so long as your not on a hill!!!
Old Jul 15, 2005 | 06:50 AM
Tarzan26's Avatar
Manual and braking
Well i agree with the rest on the leave it in D if it is an auto.
For a standard if you are just putting it in neutral and braking .. ya it will save your clutch and mess your brakes alot faster. I would say learn how to drive a standard right and rev match when downshifting.. that will use the clutch but not very much if your good. that is why all the expensive cars that have that tiptronic crap do it for you.. bip the gas bring it up to the rpm it would be at if you were in a lower gear and let out the clutch. it does take some practice but i can do it as smooth as putting it in neutral.. and costing/braking.. try it!!
it is also ver good for going into a corner .. rev match as your going in and accelerate out.. just like the pros do!!
anyway .. thats my 2 cents.. take it or leave it!
Old Jul 15, 2005 | 11:27 AM
Wow, thanks for all the replies and sharing your knowledge Everyone! My old man, which I consult with a good 95% of my ideas with, said the same thing; basically I have more stopping power when I'm in '[D]rive', I think his basis for it was that while it's in this gear the transmission is engaged, but in neutral there's nothing there.
Rest assured, i'll take all your advice and never do this to my Maxima, maybe to my mom's subaru...
Old Jul 15, 2005 | 11:30 AM
chernmax's Avatar
There is hope for you yet young Jedi...
Old Jul 15, 2005 | 02:44 PM
njmaxseltd's Avatar
Correct, even an auto keeps engine RPM's up slightly while your braking. The brake power booster works on vacuum. Higher RPM's will keep vacuum available to assist your stop. If you pump your brakes rapidly you can loose vacuum which can effect your stopping distance.
Pump your brakes 2 or 3 times with the engine off and you'll see what I mean.
Your engine is basically an air pump. Keep it pumping and you get power out of it. The more air you put through it, the more power it makes.
Old Jul 25, 2005 | 05:53 PM
Mxrider52's Avatar
I support for what?
Better hope you dont have to make a quick get go if someone flying up behind you that gonna possible hit you being in neutral aint such a good idea unless it a manual
Old Jul 25, 2005 | 06:12 PM
TXT-1's Avatar
Translation: I think what he is saying is what happens if you need to do an emergency maneuver to avoid getting rearended or possibly hitting something or someone in front of you by accelerating around it or getting out of the way? If you're in neutral and in a panic situation, you may find yourself revving, but not going anywhere since you forgot to put the car back into D.
Old Jul 25, 2005 | 06:20 PM
killerVQ30DE's Avatar
Why would you put the car in neutral going down hill
Just stick it in 3rd or what ever that gives you the proper ratio so your coasting and not engine braking.
Old Jul 25, 2005 | 06:39 PM
Loe max's Avatar
Depending on how fast you're going. If your at idle vs. lets say going 96.3242452435243mph
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
pjgreek
Sep 9, 2015 09:30 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
