Is the clutch gone?
Old Jul 18, 2005 | 07:43 AM
godlyone's Avatar
ahhh! cliMAX!
Is the clutch gone?
I looked over a potential car the other day, and I am pretty sure the clutch is gone.
Normally, the clutch grabs halfway of being released.
This was on a 2k2 btw.
His clutch grabbed when it was like 98% released...
I doubt it is not properly adjusted because the guy's father is a mechanic.
How much would a new clutch run? around $700 ?
Old Jul 18, 2005 | 10:43 AM
97BlackSEGold's Avatar
disk = $70
pressure plate = $130
release bearing = $25
So about $225 plus install unless you do it yourself
Old Jul 18, 2005 | 10:48 AM
godlyone's Avatar
ahhh! cliMAX!
how about including install?
From what I am describing.. it seems like there is almost no clutch at all left right?
Old Jul 18, 2005 | 03:06 PM
Micah95GLE's Avatar
The quickest way to test the clutch is to stop the car in an open area (parking lot with nothing around the car), put the transmission into 6th gear, and try to take off from a dead stop. A good clutch should stall the car. If you can rev the engine and get the car moving in top gear, the clutch is probably toast.
Old Jul 20, 2005 | 11:33 PM
acidspit86's Avatar
why dont you just floor it in like second gear at 20mph, the tach jumps up but you dont feel a push, then its slippin
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
