How true is it to wait 72 hours after resetting the ECU to pass inspection?
Old Aug 2, 2005 | 05:44 AM
deezo's Avatar
I just had my KS replaced on Sunday and plugged my stock ECU back in this morning for inspection. The computer failed me because it had recently been plugged in. I'm assuming that the ECU resets after being unplugged for a long time. I'm not throwing codes at all but it's been months since I drove with the stocker.
I do have 60 days to let the ECU get used to the engine and KS but they tell me to wait 72 hours then come back. I'm thinking about waiting longer.
What do you guys think?
Old Aug 2, 2005 | 07:08 AM
DJ2Max's Avatar
don't you have to drive it around for a little while so that it can gather information?
Old Aug 2, 2005 | 07:12 AM
Maximum Performance's Avatar
i think it is about 40-50 miles or so for the ecu to cycle all the systems once
Old Aug 2, 2005 | 08:53 AM
deezo's Avatar
I drove it 45 miles to the shop.
Old Aug 2, 2005 | 10:11 AM
MDeezy's Avatar
I was told its about 200 miles for the ecu to "re-learn" and adapt. I say wait a bit longer.
Old Aug 2, 2005 | 10:21 AM
njmodi's Avatar
Do I get a tax break?
to what MDeezy said.. It think it takes on the order of 200-250 miles and a few complete cycles to get the ECU out of its "just reset" state.
Deezo - make sure you turned the ECU screw back all the way - I know someone else had a problem where the car would never exit this "learning" mode and it turned out to be their ECU screw was not turned all the way anti-clockwise to its stop.
Cheers.
Old Aug 2, 2005 | 11:12 AM
deezo's Avatar
Cheers.
I'm using the Equuis to reset the codes but I'll wait until next week to go back.
Old Aug 2, 2005 | 11:14 AM
njmodi's Avatar
Great - just make sure the ECU screw is in the right position. Even if you haven't touched the screw recently, if its not locked all the way anti-clockwise, the ECU may not complete the test mode.
Old Aug 2, 2005 | 12:12 PM
C MAX's Avatar
i heard seven days for the computer to recycle or a certain amount of miles.
Old Aug 2, 2005 | 08:19 PM
AsthmaMax11's Avatar
Wouldn't the ECU rely on miles rather than "days"?
Old Aug 2, 2005 | 08:23 PM
sean05's Avatar
how about an airbag light? i accidently snipped the wrong wire the other day. I reconnect the wires but the light wont go out. i did the little door trick but it didnt work. Im just about to take the bulb out.
Old Aug 3, 2005 | 04:29 AM
deezo's Avatar
Well, they just said 72 hours assuming that I will be driving the car around giving the ECU time to get used to everything. They caution people to not bring it in for inspection right after resetting the ECU.
Old Aug 3, 2005 | 09:27 AM
bendy's Avatar
any one know what a ecm code 53 for a 95 maixima gxe (fed specs) is.
Old Aug 3, 2005 | 09:29 AM
MDeezy's Avatar
Front Right Heated O2 sensor
Read the stickies
Old Aug 3, 2005 | 10:06 AM
HenryNYC1's Avatar
Info from a friend of mine who is a shop owner says its not time but mileage put in for the computer to be in a "ready" state before testing can be done. He said usually 100-150 miles would do it.
Old Aug 3, 2005 | 10:28 AM
I30tMikeD's Avatar
I had the same problem the last two times I emission tested. It had been days and many miles since I had reset the ECU before I went in, but they still could not get a reading. I don't know the exact mileage or time the car has to run before the ECU can be scanned but I went back a week later and they still could not read the ECU. Then a week after that it worked.
Old Aug 3, 2005 | 12:59 PM
bendy's Avatar
Old Aug 3, 2005 | 01:06 PM
deezo's Avatar
Cool, I'll just wait a couple of weeks because I don't feel like paying them another 30 bones.
Bendy: If you post in this thread again, I'm giving you some time off. Go read the stickies in the 4th Gen Forum.
Old Aug 3, 2005 | 01:30 PM
MDeezy's Avatar
they charge you for getting your emissions done again? I thought it was a standard that if you fail emission you have 30 days to get the problem corrected and re tested for free
Old Aug 3, 2005 | 01:39 PM
deezo's Avatar
The last time I failed with my truck, they told me I get one try or something like that but I'll find out for sure.
Old Aug 4, 2005 | 08:33 AM
HenryNYC1's Avatar
If the shop owner is cool, They can hook a ODBII scanner to your computer and check if the system is ready for emission test. I seen people with MIL on and they fix the car and had to drive around for hours till the system was in "ready" state. Did all this with the ODBII scanner plugged in so they knew exactly when it was eady to test. He also did mention that not all fields must be in "ready" state to test. I was told newer cars need less "ready" fields than older ones. Sorry but I can' remember how many.
Old Aug 8, 2005 | 08:04 PM
Inspiron's Avatar
I think it depends on the kind of driving you do not just miles and time
Old Aug 9, 2005 | 04:35 AM
MaximaSE96's Avatar
Maxima Owner
usually 1 week to 10 days of normal driving should be fine...or a roadtrip somewhere
Old Aug 9, 2005 | 01:50 PM
Max96GLE's Avatar
What my mechanic told me:
Fail inspection
Speed sensor code
Replace sensor
Reset CEL
Drive 60 miles (continous highway and local)
Pass inspection
Hope this will be able to help you.
Mar 12, 2020 12:06 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
220k+ A32
Sep 22, 2015 03:08 PM
