stainless steel clutch line
Old Aug 2, 2005 | 06:01 AM
max723's Avatar
anyone have one of these. what are the benefits of it?
Old Aug 2, 2005 | 10:11 AM
MDeezy's Avatar
better pedal feel, less prone to leaks.
Old Aug 2, 2005 | 11:45 AM
SPiG's Avatar
SomePsychoGuy
Much cheaper than the OEM replacement. It seems to be a common problem with 4th gen 5 spds. I really like mine.
Old Aug 3, 2005 | 11:51 AM
wed3k's Avatar
hmm, looks like something i have to look into.
Old Aug 3, 2005 | 01:02 PM
BSwithTF's Avatar
Did you guys that have this get it from the group deal that was going on or if not, what was your source? Did it replace both the rubber lines or just one of them? The line coming off the slave cylinder is leaking on mine.
Old Aug 3, 2005 | 01:26 PM
MDeezy's Avatar
got it fromt he GD, its still going on. Not sure but I believe it replaced both lines. . . been so lazy I need to install mine
Old Aug 3, 2005 | 01:51 PM
i30ds's Avatar
Armed and Dangerous
Got mine from the GD... Love it! the price is really good. Supposedly many tried to replace both rubber lines with it but had problems so people jstarted just replacing the upper rubber hose... However, I replaced both rubber lines with mine with out a problem... Hell, I had lenght to spare!! Its all in the GD thread.
Old Aug 3, 2005 | 03:33 PM
VQuick's Avatar
Chassis Freak
$25 shipped in the group deal; I was one of the first to get it back in November. It's a high quality Technafit line. It does indeed replace BOTH rubber clutch lines as well as the stupid junction box between them. If you only replace one of the rubber lines, you will still have a lot of flex in the system. Replace both.
It made a small but noticeable difference in clutch feel. Don't expect a huge change.
Old Aug 3, 2005 | 03:58 PM
max723's Avatar
im reading that a few people said the line was to short. also the deal was for only 1 line. what do you mean upper and lower lines-its ok to replace just 1 with ss?
Old Aug 3, 2005 | 07:06 PM
VQuick's Avatar
Chassis Freak
Yes, just one line is needed, just make sure you tell him what year Maxima you have. Line length problems were fixed long ago, should be a perfect fit.
Old Aug 3, 2005 | 10:24 PM
Jar's Avatar
Jar
is a perfect fit, love mine, it replaces from the bell housing to the metal line, you'll have no rubber and no lame junction box, get it its a great deal and an easy install
Old Aug 4, 2005 | 07:40 AM
BSwithTF's Avatar
Ordered me one last night.
Old Aug 4, 2005 | 07:47 AM
max723's Avatar
from where- the GD?
Old Aug 4, 2005 | 09:28 AM
SPiG's Avatar
SomePsychoGuy
Look in the GD forum. SS clutchline for 95-01 maximas.
The first batch was originally intended to just replace one line I think. When I bought mine in the first batch it was a tad short to reach the bracket on the frame so I just bent the hard line (brake type hard lines do have some flexability). It was far too long to replace only one and maybe 1/2" short to replace both. Now the length is fixed and it meant to replace both.
With any stock or stage 1 clutch don't expect a huge difference in feeling, but it should be much more reliable than the stock rubber line that likes to leak after a while. If it ain't broke then I wouldn't replace it unless you were doing a swap.
Old Aug 4, 2005 | 04:47 PM
shoman94's Avatar
Does this work on the GEN 5.5 6speed?
Old Aug 4, 2005 | 06:43 PM
max723's Avatar
so thers none for 3rd gens?
Old Aug 4, 2005 | 10:06 PM
Cliff Clavin's Avatar
Way out West
You can get one for a 3rd gen. At least you could. I have one and so does MrGone. I think some others have it, too. I just haven't gotten around to installing mine
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
doctorpullit
Dec 12, 2015 09:39 AM
