Further impressions of the VB mod.
Old May 23, 2001 | 01:50 PM
JJW95SC's Avatar
The weather is still crappy here (NJ) but at least it's not a downpour like the last 2 days. I like how the car shifts much better now. Under moderate stomp, perhaps 1/2 pedal from a stoplight, the car shifts as quickly as it takes to snap your fingers. The real test will be on the highway when I 'put my boot into it'
If it is sunny tomorrow, I'll take it for a longer ride.
Jim
Old May 23, 2001 | 02:02 PM
1MAX2NV's Avatar
Jim,
So what was your tranny problem? Did you get a rebuild? Did you go to JimW's tranny guy?
Jim
Old May 23, 2001 | 07:27 PM
JJW95SC's Avatar
Originally posted by 1MAX2NV
Jim,
The tranny was cooked. I didn't see it after they took it out but that was all she wrote. I had a Nissan reman installed by a dealer. Not cheap but it was cheaper than Level10, even after adding Don's VB. I also got an 'unofficial' warranty on the tranny since I know a bunch of the guys at this dealership.
Jim
Old May 23, 2001 | 09:32 PM
bigtexan7's Avatar
I got mine about a month ago, just wait until you stomp it from a red light, it gets even better!
Old May 24, 2001 | 12:42 AM
JJW95SC's Avatar
Bigtexan,
Do you have a 4th gen? What other mods do you have? What brand of ATF are you running now? I put some cheap crap in there when we made the swap but just picked up some Mobil1 ATF. Not cheap at About $80 for 12qts but this tranny has to last!
I'm looking forward to chirping into 3rd like I used to when I had stock 15" wheels and the SC. This might be asking too much though.
Jim
Old May 24, 2001 | 06:48 AM
AntGVR4's Avatar
hey
Jim,
I used Mobil1 synthetic ATF when i swapped my VB..It is more expensive yes but the better protections against heat it gives is worth it IMO...
it's only been about 2K miles with the VB but when i romp on it for a while i check the fluid and it's always good ...
Ant
Old May 24, 2001 | 09:21 AM
bigtexan7's Avatar
Jim, I've got a y-pipe, hi-flo cat, Jim Wolf ecu and a CAI. Yes, I use Mobil 1 with an external cooler. It really seems to keep temps down. I looooovvvvveeee my Vb, I no longer feel guilty on the trans' behalf when I race it!
Old May 24, 2001 | 10:04 AM
1MAX2NV's Avatar
Hmm..Why didn't you go with JimW's tranny guy? If I recall correctly, the hi-po rebuild set him back like ~$3K including labor. How much was the reman. + installation?
I was one of the first people to get a tranny cooler. I knew how bad the OEM cooler was. I would flush the fluid every 20K miles with Mobil 1.
Jim
Old May 24, 2001 | 10:53 AM
JJW95SC's Avatar
The new/reman Nissan tranny was $3600 including a new radiator and all labor. Money wasn't the only issue. Timing was an issue as was hassle. The dealer was reasonably close to home, right on my way to work, they could do it right away, gave me a loaner car, and I know them pretty well.
I didn't want to pay to have the car flatbeded (sp?) all the way to SI, arrange my own rental and then have to drive out there again when the car was ready. My time is worth some money also. I had already missed some time at work that I had to make up before the contract was up and bringing the car to SI would have meant even more downtime and late nights at work. Looking at the big picture, I think I made the best choice.
Now I have a new trans with Don's VB and I should be set.
Jim
Old May 24, 2001 | 01:13 PM
BlkCat
When you get the chance to stomp it, let us know! I've faxed my form to Don. Can't wait to feel the difference with my SC off the line!
Old May 24, 2001 | 03:40 PM
black97max's Avatar
You wont feel anything off the line. The valve body only changes the upshifts and downshifts. You will experience tighter shifts from 1st to 2nd and 2nd to 3rd.
Old May 24, 2001 | 03:50 PM
teejnut's Avatar
can't wait till i get $ for this mod
Old May 24, 2001 | 03:53 PM
BlkCat
LOL...thats what I meant Black97Max. Tighter shifts off the line.
Old May 25, 2001 | 01:16 PM
BlkCat
Any updates?
James92SE
142
Jan 2, 2024 09:23 AM
mclasser
22
Nov 12, 2020 01:58 PM
Dasmith
Sep 23, 2015 08:28 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
