Nissan Consult interrigator..
Old Oct 2, 2005 | 02:48 PM
  #41
killerVQ30DE's Avatar
Originally Posted by I30tMikeD
To clarify, with the OBD Tech Scan program we got it to use the "ECU Finder" and it found 2 different ECU code things... FF FF E7 and FF FF ED. Then we click step 2 which is "auto scan" and it says:
Transmit: FF FF E7
Recieved: FF FF E7
Register: Failed
And we can't get any further than that. We used "Register Finder" and got no results from that. It scanned through a bunch of stuff but didn't give us any indication that any of the registers worked.
OBD scantech worked for me when Nissan Datascan didn't
For me I just choose the Engine ECU (rather than trans) and hit Autoscan.. those codes you see (hex ones) are the init string being sent to the ECU.
Old Oct 2, 2005 | 06:26 PM
  #42
liqidvenom's Avatar
brotherhood of tq
u have to take those ecu code things it give to u and actually imput them into the program...let me check where u put it in exactly.
Old Oct 2, 2005 | 06:33 PM
  #43
liqidvenom's Avatar
brotherhood of tq
ok once u manually do a search and get the codes that works for your ecu, u then take those figures and on the bottom of the connect page it should say advance under the ecu finder tab. click on the advance and then add the code u got and then hit auto scan once again. if that doesnt work pm me and let me kno
Old Oct 2, 2005 | 06:34 PM
  #44
liqidvenom's Avatar
brotherhood of tq
i also use the ff ff ed set of codes
Old Oct 2, 2005 | 07:21 PM
  #45
2 Da Max's Avatar
ok i got a laptop, and im on the site... where the fawk do i get the wire?
Old Oct 3, 2005 | 01:32 PM
  #46
liqidvenom's Avatar
brotherhood of tq
u get the cable from plms which has a link in page on of this thread
Old Oct 22, 2005 | 07:48 PM
  #47
liqidvenom's Avatar
brotherhood of tq
it seems that version 1.5 has just come out
Old Oct 22, 2005 | 08:57 PM
  #48
Kevlo911's Avatar
Kevlo for President
More features? Better support? Faster?
Old Oct 22, 2005 | 09:22 PM
  #49
MrGone's Avatar
been there, done that
sold the 5th gen, stopped caring
Old Oct 22, 2005 | 11:31 PM
  #50
liqidvenom's Avatar
brotherhood of tq
i just got the email n ive been to lazy to go out n try this new version, ill give it a shot n let u guys kno if i like it
Old Oct 28, 2005 | 10:38 AM
  #51
hightuner's Avatar
Nissan maniaco conpulsif
This is very interesting thx you guy s
but what the advantage of consult 2 over stardart obd2
EDIT: I found some nice stuff over Phatg20 forums
theres the diagram +
ECU-ID's
Gneric Nissan Engine ECU Register Table
Nissan ECU Consult Protocol Definition
Nissan ECU Consult to PC Interface
REF: http://www.phatg20.net/modules.php?n...ownload&cid=51
Old Oct 30, 2005 | 03:55 PM
  #52
krismax's Avatar
Father of the 00 VI
what exactly can you change ? can you with it hooked up change rev limit,timing stuff like that?
thanks
Old Oct 30, 2005 | 04:11 PM
  #53
SR20DEN's Avatar
VQ Wizard
ECU-ID's
I see he finally posted the entire '94-'06 Nissan/Infiniti ESM collection I gave him three months ago.
Old Nov 17, 2005 | 12:36 PM
  #54
igzy's Avatar
I Know Kwaliti
What a bummer... Tried going there... PhatG20.net - This domain has expired
Old Nov 19, 2005 | 09:12 PM
  #55
DandyMax's Avatar
3.5 in the works
I have both the DataScan and the ScanTech. Personally I like the latter better, as it includes more custom setup flexibility and will work with almost any Consult-I interface (virtually any Nissan pre-year 2000, either OBD I or II). These programs don't work with Consult-II which uses different protocols.
Both these programs are essentially scanners/dataloggers which are faster and include extra functionality over an OBD scanner since they use the Consult port not the OBD port. You can datalog, pull/clear codes, and do active tests such as TEMPORARILY adjusting timing, turning off cylinders etc. On the 4th gen Max you cannot however, change rev limits or timing/fuel maps permanently with them. This is a limit of the ECU having only a PROM, not an EPROM. You cannot write to the chip, only read from it. The ECU ROM can be downloaded as a .bin file and certain addresses watched etc but you can't upload a new program. It could be used to potentially compare aftermarket and stock maps if you could find the appropriate address ranges.
For those who are trying the ScanTech, you'll notice that you can select the module to access (engine, a/t, a/c, hicas etc). HICAS is for the 300zx and not applicable. Each module has an initialization code that must be sent in order for connection to be established. This is what the program is doing when you scan the ECU, it's scanning to see what the valid strings are.
I have found that the engine init string for a 96 is FF FF EF and for a 98 is FF FF ED. I've also used the program on older cars such as a Sentra with no problems.
For any vehicle, if it's the first time hooking up to it, I'd do the ECU scan. It'll generally give you three or four init strings. You can then try setting each of them under the advance button 'engine' field until you find the right one.
On another note, I have tried the free Conzult and Ztalk but they do not seem to initialize or report properly with the A32.
Old Nov 21, 2005 | 01:00 PM
  #56
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Anyone want to sell me the Serial->Consult cable?
If so, which one is it?
Mar 12, 2020 12:06 AM
Bernhard
Sep 14, 2015 12:49 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
coasterswim
Sep 2, 2015 07:43 AM
