Is the s/c worth the $$?
Old May 24, 2001 | 05:16 PM
bosco500's Avatar
Just curious to everyones opintion that is s/c'ed. Is it worth the 3500 bucks? Does it make your blood pump @ 8000 RPM's?
Old May 24, 2001 | 05:19 PM
Sprint's Avatar
yes
Old May 24, 2001 | 07:05 PM
The New CLIMAX's Avatar
Originally posted by SprintMax
yes
I think so, but remember to tune tune tune.
Old May 24, 2001 | 07:11 PM
bosco500's Avatar
what exactly do you mean by tuning?
Old May 24, 2001 | 08:28 PM
Phil02E46's Avatar
to get to 8000 rpm.. your gonna have to do some massive tuning
other than that its FUN!
Old May 25, 2001 | 05:19 AM
Vic's Avatar
Vic
buahahaa... sounds like something i said in the past...
Vic
Old May 25, 2001 | 07:40 AM
Vinipux's Avatar
specifics
can you be more specific, what exactly do you mean by that? tunning by upgrading or tunning by adjusting?
Old May 25, 2001 | 08:39 AM
Can't Post :)
Vic
Exactly Vic told me as soon as I got the S/C and he is 100% correct, without tunning the SC is worthless, and tuning means, Air/fuel ratio, making sure you get on a dyno with the probe to measure the fuel ratio's. I also spoke with Loren and he also has done lots of tuning on a Dyno and that makes all the difference. Just for example. I am running 14.6 at 98 MPH, but I have not tuned at all, and there are guys that have a y-pipe and CAI, and are running low 14's on a 5th gen. So if you look at in that respect yes I spent 4K for nothing. But once I tune her and get her a little leaned out, she has too much fuel I will bee in the low 14's maybe high 13's but I also still need an Y-pipe, new clutch, RT CAT, there is still alot to go. But if you follow VIC's advise and try to perfect the tuning you will be good. Thanks agian VIC
Old May 25, 2001 | 08:51 AM
Phil02E46's Avatar
Re: specifics
well for starters i wouldn't recomend running your engine up to 8000rpm.. does the maxima tach even go that high?? other than that.. its pretty simple..
Old May 25, 2001 | 10:03 AM
bosco500's Avatar
i didnt mean the engine @ 8000 RPM, i meant does you blood pump @ 8000 RPM when you stomp it
Old May 25, 2001 | 10:07 AM
s1rch's Avatar
yes, yes, yes
Old May 25, 2001 | 01:13 PM
BlkCat
It sure does!
Old May 25, 2001 | 08:08 PM
Andre 3000's Avatar
is it worth supercharging an auto max
Old May 26, 2001 | 02:12 AM
OgreDave's Avatar
Ill let you know by next weekend, hopefully..
Forge277
Jun 13, 2016 09:26 PM
lrb6805
Sep 30, 2015 08:12 AM
homewrecker
Sep 24, 2015 07:01 PM
Dasmith
Sep 23, 2015 08:28 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
