I was changing my radiator fluid and......
Old Aug 30, 2005 | 07:20 PM
HoldTight's Avatar
Here in Colorado you can pour your antifreeze down the drain. So, after work I went to the store and purchased 5 gallons of distilled water to go with the Nisson ant-freeze I had already purchased. Then I drove straight to my local car wash and parked my car right over the drain in the wash bay. That is when it happened, as I pulled the plug and the HOT ant-freeze started pouring down on my hand I pulled away and the drain plug fell straight for the drain but lucky me it stopped right on the edge of the drain. After that I pulled the car forward and proceeded to drain and refill. I hope this helps someone else who thinks they are smart like me.
HoldTight.....
Old Aug 30, 2005 | 07:28 PM
wunfstmax's Avatar
way to represent us colorado people....
Old Aug 30, 2005 | 09:00 PM
MIKE2K2's Avatar
Custom User Title
I can shoot myself, but I choose not to.
Just because you are "allowed" to do something, doesn't mean you should. You should dispose of all fluids in a safe and responsible manner.
Old Aug 30, 2005 | 09:03 PM
HoldTight's Avatar
I am not the Department of Water I don't make the rules I just abide by them.
Go back under your rock.
HoldTight...
Old Aug 30, 2005 | 09:06 PM
Turk's Avatar
ohhh man you gonna get bashed, not in Colorado, but on the ORG......
Old Aug 30, 2005 | 09:11 PM
MIKE2K2's Avatar
Custom User Title
Originally Posted by HoldTight
Here in Colorado you can pour your antifreeze down the drain. So, after work I went to the store and purchased 5 gallons of distilled water to go with the Nisson antI-freeze I had already purchased. Then I drove straight to my local car wash and parked my car right over the drain in the wash bay. That is when it happened, as I pulled the plug and the HOT ant-freeze started pouring down on my hand I pulled away and the drain plug fell straight for the drain but lucky me it stopped right on the edge of the drain. After that I pulled the car forward and proceeded to drain and refill. I hope this helps someone else who thinks they are smart like me.
HoldTight.....
NISSAN.....Not enough Nissan logos around for you to spell it right?
Old Aug 30, 2005 | 09:14 PM
HoldTight's Avatar
I am putting on my asbestos suit as I type....
OK im ready. Go for it.
HoldTight...
Old Aug 30, 2005 | 09:23 PM
Maxima lover
How hot was the anti-freeze? My grandma was having her radiator flushed in her motor home and the guy got it all over his arm and it started to peel the skin off. Maybe yours wasn't as hot.
Old Aug 30, 2005 | 09:37 PM
HoldTight's Avatar
It was hot but I tend to be pretty thick skinned. It did not leave a mark. I was to impatient to wait for it to cool down after every time I filled with water and let the engine run for 5-10 minuits.
HoldTight...
Old Aug 31, 2005 | 05:39 AM
nupe500's Avatar
Jedi Knight
Clearly you are a dummy....not only do you add to the pollution cause they say its ok...but you change your fluid while its hot....You should consider yourself very lucky that it didn't spray into your eyes...u would likely be blind...glad u are in Colorado...
Old Aug 31, 2005 | 05:55 AM
Mizeree_X's Avatar
Getting back to his roots
I also like how you didn't even have the ***** to dump the toxic waste down your own drain, so you drove somewhere else to do the dirty deed.
Old Aug 31, 2005 | 09:31 AM
Jeff92se's Avatar
I'm needing a caw
I put it in bowls and let the local cats drink it.
Old Aug 31, 2005 | 09:55 AM
Mizeree_X's Avatar
mmmmmm....sweet suicide
Old Aug 31, 2005 | 10:07 AM
s0ber's Avatar
Old Aug 31, 2005 | 10:42 AM
Stephen Max's Avatar
pktaske
May 6, 2016 07:49 AM
RWCreative
Sep 21, 2015 11:01 AM
iamute
Sep 20, 2015 05:22 PM
Maxxx10
Sep 13, 2015 03:16 PM
pktaske
Sep 4, 2015 08:40 AM
