What is involved to make the speedo work?
Old Oct 2, 2005 | 03:29 PM
dmontzsta's Avatar
Ford Only.
I recently swapped trannies on my 97 and the speedo has not worked. I did crack the little plastic drain plug that has the wire connected, not sure if that would make it no work?
Old Oct 2, 2005 | 03:34 PM
MrGone's Avatar
that would be the speed sensor
Old Oct 2, 2005 | 03:36 PM
dmontzsta's Avatar
Ford Only.
yeah. I did superglue the little piece back on. It was just a corner that broke, it just looked like solid plastic, didnt look like it would do much? Do you think that would make it not work? just a little corner?
Old Oct 2, 2005 | 03:38 PM
MrGone's Avatar
I wouldn't think so but it could have been broken before hand.
Why not try swapping the old one?
Old Oct 2, 2005 | 03:40 PM
dmontzsta's Avatar
Ford Only.
I did pick up a 2k tranny. I will take the one off that and try it.
Is that the only thing involved in making it work? I mean, as long as the harness is plugged in, then it goes back to the ecu? nothing else involved?
Old Oct 2, 2005 | 04:48 PM
nismology's Avatar
What you cracked is actually the reverse/neutral position switch. The vehicle speed sensor/speedometer pinion is right above the differential on the back side of the tranny. It's directly above where the control rod connects to the tranny.
jerrod99_se-l
Aug 27, 2015 08:27 PM
criminalslang810
Aug 16, 2015 08:12 AM
Max8
Aug 15, 2015 07:06 AM
Samedi
Aug 12, 2015 01:54 AM
kenc15
Aug 5, 2015 08:29 AM
