Need Help with relay, its doing the opposite of what i want it to do
Old Oct 10, 2005 | 05:49 PM
2 Da Max's Avatar
ok so im wiring a relay on my car,its suppose to keep something off, unless i place somethin on it
but instead its always on, and when i place something on it, it turns off.
need help
ok its a bosch relay
here goes
85 and 87 are getting power
87a is the ground
86 and 85 have the other sides of the wire that are not powered
Old Oct 10, 2005 | 06:00 PM
pmohr's Avatar
No more Maximas...
need help
There are normally closed relays, and normally open. You have an NC, you need an NO.
Old Oct 10, 2005 | 06:02 PM
2 Da Max's Avatar
how do i know which one is which? ok also have a tyco one besides the bosh
would i damage anything if switch the wires on the relay?
Old Oct 10, 2005 | 06:29 PM
RA030726's Avatar
I'm nutty for Nissans
86 and 85 are trigger.
30 connects to 87a with no power.
30 connects to 87 when power is supplied.
basics:
http://www.bcae1.com/relays.htm
Old Oct 10, 2005 | 06:42 PM
2 Da Max's Avatar
right now i have 30 and 87
should i put it at 30 and 87a?
but when i put the ground on 87 the relay sparks, and doesnt spark when i have it on 87a
Old Oct 10, 2005 | 07:01 PM
shavedmax's Avatar
i dont think i've ever used 87a on a relay. i dont have one in front of me but i think normally 85 and 86 are the trigger(one being grounded and the other giving power ( in your instance you place something on it). then 30 and 87 are power and what you want to turn on.
edit, i just read jsutter's, his is much simpler to undertand
Old Oct 10, 2005 | 07:03 PM
LatinMax's Avatar
Wrong: Bosch does both.
Correct
Old Oct 10, 2005 | 07:59 PM
shavedmax's Avatar
is it just me or are the quotes the same?
Old Oct 10, 2005 | 09:13 PM
2 Da Max's Avatar
ok still not working.. tried it as much ways as possible
Old Oct 11, 2005 | 05:01 PM
99se5spd's Avatar
85 to ground
86 to "unless i place something on it" which should be +12v
30 to +12v
87 what you want to turn on
gavin68
Sep 18, 2021 12:36 PM
AaronL
Nov 15, 2020 11:52 AM
zmcneely13
Sep 26, 2015 02:26 PM
MaxDD
Sep 24, 2015 06:40 AM
