View Poll Results: S-AFC II or V-AFC II
S-AFC II
![](https://maxima.org/forums/images/maxima/polls/bar2-l.gif)
![](https://maxima.org/forums/images/maxima/polls/bar2.gif)
![](https://maxima.org/forums/images/maxima/polls/bar2-r.gif)
![](https://maxima.org/forums/clear.gif)
34.78%
V-AFC II
![](https://maxima.org/forums/images/maxima/polls/bar3-l.gif)
![](https://maxima.org/forums/images/maxima/polls/bar3.gif)
![](https://maxima.org/forums/images/maxima/polls/bar3-r.gif)
24
52.17%
other -please specify below
![](https://maxima.org/forums/images/maxima/polls/bar4-l.gif)
![](https://maxima.org/forums/images/maxima/polls/bar4.gif)
![](https://maxima.org/forums/images/maxima/polls/bar4-r.gif)
13.04%
Voters: 46. You may not vote on this poll
SAFC II vs. VAFC II
#42
Originally Posted by crossfire
so you really wouldn't need to get an SAFC or VAFC if you are not running nitrous or would it provide advantageous gains in speed/acceleration?
With nitrous, you want to ADD in more fuel for detonation insurance. Especially with dry kits. With wet, you typically run a little bit leaner, but nothing to worry about. But for the automatic, I had just added in 1% fuel correction under 3.5k and 2% over 4k to just make sure I wasn't going to lean out far enough to cause detonation during nitrous.
If you're stock, or just have an intake and/or a cat-back, it isn't really worth getting it since your A/F will still be pretty close to stock.
And who the hell needs the VIAS butterfly valve?
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
#43
![Popcorn](https://maxima.org/forums/images/smilies/popcorn.gif)
And who the hell needs the VIAS butterfly valve? I removed that and gained some good power up-top. I guess it's a 3.5 thing.
Read this --> http://forums.maxima.org/showthread.php?t=512483
Been debated quite a bit lately. Maybe you should dyno and post the results to end the debate.
#48
Anyone check out the APEXi AFC NEO? I saw it up on their site and it seems like they're saying it can do everything both SAFC II and VAFC does? any merit to this?
Damnit, i wish they just made a harness for our cars. . .I'd really hate soldering all that crap in and frying my ECU...
#49
Explain to me as to why a harness would be better?
There are only a handful of wires to tap in the case of these AFC's. A harness would be almost a waste of time/effort.
I went into it w/ absolutely no soldering/ECU/wiring experience whatsoever. Armed w/ a soldering iron, solder, an FSM, and some extra wire. In the end myself and my ECU both came out alive.
#50
mostly because I'm interested in plug n' play, easily reversible, and the fact i have no warranty sometimes makes me a little hesitant to just go at my only car with a wiring diagram off the net and a Solder Iron. i fry it i don't have alternate transportation ![Frown](https://maxima.org/forums/images/smilies/frown.gif)
EDIT; well, Nothing lost, nothing gained. I'll nab one in a few paychecks and maybe luck out and be the only 5.5genner to play with one.
#51
![Fruit](https://maxima.org/forums/images/smilies/fruit.gif)
litch
123
01-04-2024 07:01 PM
