The Maxima Christmas Thread
Originally Posted by Parker Woodruff
I've replaced everything that could possibly break down on the car.
Pistons
rods
bearings
gaskets
TPS
ECTS
Thermostat
radiator
passenger side axle
control arms
inner & Outter tie rods
cross member
y-pipe
o2 sensors
shift linkage
injectors
coil packs
main harness
ecu
ingition switch
fuel pump
fuel filter
EGR
throttle cables
pcv valve
oil pump
oil pressure sensor
oil pan gasket
Crank and Cam sensors
Vehicle speed sensor
e-brake cables
brake pads
brake calipers
master cylinder
slave cylinder
Got a viper alarm/remote start, with lcd alert - purchased yesterday, installed Jan 11. getting a belated Christmas present of window tinting all the way around also in January when remote start is done.
No HIs or Lows when you have a BOSE.
Personally its an alright system, HU blows. It has some good bass in it, but it could be better, the highs definetly need some work. I am replacing my system during my xmas vacation.
Overall great system...just needs tweaked.
...and a new headunit
the reason i talk **** about the bose is that it is just so notorious for going out in one way or another. 3rd gens had problems with the head units and the speaker/amp assy's going out, newer cars usually the head units act up in many different ways. My buddy's '02 has had the head unit replaced 3 times before the 3/36 warranty was out. It would be one thing if they only had occasional failures, a small defect rate is a law of nature, but the failures are so widespread, and way too common for a Japanese car, which is expected to be reliable in almost every way. Now some people do get lucky and their bose has not had any problems and that's cool, because they do sound pretty good. But getting a bose sytem in a max is like buying a Ford, they have a rep for poor quiality and lot's 'o problems, and alot of them are junk, but once in a while you do get a decent one that is fairly trouble free. It all boils down to an unacceptably high failure rate for a component that comes in a japanese car. Maybe chrysler should get bose and nissan start using infinity systems?
WOW, I went WAAAAY off topic there, sorry for the rant, don't want to ruin the christmas cheer.
Umm, I hooked up the remote start on my alarm i got for my car for chistmas...so it's sorta like a stocking stuffer.
The shop wouldn't do it when they put it in. somethin' about a stickshift?
I'm lovin' the new tires and ST swaybars.
Originally Posted by Puppetmaster
Just wondering why the price was necessary in that listing....
I am probably picking up a used suspension, so I will finally be lowered!!! I didn't expect this. Man, I can't wait.
KYB AGX paired with either sprint, eibach, or S-Techs, depending on who I buy from.
Slamrod
Apr 10, 2016 05:24 PM
Finkle
Sep 27, 2015 09:53 PM
MikesChevelle
Aug 6, 2015 11:36 AM
