Keyless entry help?
Old Dec 31, 2005 | 05:35 PM
greg hazlett's Avatar
Keyless entry help?
I searched and saw the instructions for programming keyless entry FOB's for 04's and up but the directions did not work. Any help?
Old Dec 31, 2005 | 11:00 PM
JayMAX22's Avatar
The below is for Altimas and I tried it on my 04 Max and it worked so I'm sure it works for Altimas.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try. Good Luck
Old Jan 1, 2006 | 09:18 AM
Thanks, both of them work!
Old Jan 3, 2006 | 06:10 PM
MadMaxSE-L's Avatar
Doggah Bite...
are the directions the same for 4th gen? I tried this on my 97SE and after putting the key in the ignition 6 times, the hazards flash, but when I hit the lock button on the remote, nothing happens. I have put new batteries in the remote so I know that is not the problem. Please help I hate having to use the key to unlock everything...
Old Jan 4, 2006 | 07:15 AM
MadMaxSE-L's Avatar
Doggah Bite...
noone knows???
ah2002
Mar 9, 2016 01:42 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
