Heard some noises...took some photos
Old Jan 10, 2006 | 07:10 AM
nupe500's Avatar
Jedi Knight
Heard some noises...took some photos: Updated with after pics
Gonna be a fun weekend...
Old Jan 10, 2006 | 07:15 AM
Dubbya's Avatar
VK56 Inside
Have fun with the Rac & Pinnion boots. I did mine not too long ago. It takes about a hour a side. Passenger side being the biggest PITA.
Old Jan 10, 2006 | 08:17 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
wuss...theres anohter 50 or so miles left in those things they are still good until all the bearings and **** fall out!
Old Jan 10, 2006 | 08:21 AM
Iron Scimitar's Avatar
Tha Snatcher
fukk dat, drive it till the wheels fall off.
Old Jan 10, 2006 | 08:25 AM
gtr_rider's Avatar
192.168.1.1
I've got to do mine also
Old Jan 10, 2006 | 08:28 AM
Dubbya's Avatar
VK56 Inside
They are a pain. Toss the little metal twist ties they give you right in the garbage. Use a zip tie instead, you will save a huge headache.
Old Jan 10, 2006 | 08:57 AM
nupe500's Avatar
Jedi Knight
Dubbya...good advice...
DA-Max/Iron S.---thanks for the advice post ******....and don't worry...I'ma drive that bish till this weekend...gonna end up doing a whole bunch of work on the car...ie...what you see there...changing tranny fluid....doing front strut mounts and bearings....wanna come help?...
Old Jan 10, 2006 | 09:11 AM
Dillbag's Avatar
Suprise butsechs!!!
heck, i drove on my first set of axles until all of the boot was gone and no grease left, just dirt, rocks, and bugs in the joints, and still no noise. eventually i got new ones.
and +1 on the zip tie idea.
Old Jan 10, 2006 | 09:16 AM
Dubbya's Avatar
VK56 Inside
Another thing that made it easier is this:
Imagine these are the end holes of the boot
o O
The larger of the two goes towards the inside to fit on the steering rac set up. The boot is a hella tight fit. I found it much easier to turn the larger end inside out, push it on to the steering rac and then flip it right side out around the steering rac. After that slowly pull the boot back to its proper seating place. I hope that make sense.
Old Jan 10, 2006 | 09:21 AM
shurik's Avatar
Something like that here...
Yeah I have and had some problems with my passenger side one. It's just leaking the grease out everytime I drive, not from the boot, but from them clamp. The boot itself is good but the clamp that holds it just doesn't hold it tight enough I guess. I've replaced the clamp like 3 times and still is leaks the grease. I don't know those universal clamps just suck guys, I need the actual OEM one which is almost $8 from the stealer just for one boot clamp. I had broken ring on the axile not a long ago, that's when my axle came off the bearing that holds it. I don't know how that happened, but I think my boot did that and it's all cause of those clamps.
Anyone know a good place where I can buy an actual OEM clamp not something like this...
http://www.prostreetonline.com/oem/q...tion=000801897
It says it's an OEM one, but it's realy not. I tried that one and it's a horrible design, can't even tight it hard enough.
Old Jan 10, 2006 | 10:53 AM
gtr_rider's Avatar
192.168.1.1
sounds like a good idea. Also, was the rack/pinon making noise or were you referring to the CV Joint because I have a hard rubber to hard rubber noise when I make left hand turns. Only thing I could think of is the steering rack dust boot rubbing against the FSB bushing(S-techs, no alignment yet)
Old Jan 11, 2006 | 06:22 AM
sean05's Avatar
i gotta do the samme thing. got the replacement sitting in the garage.
Old Jan 12, 2006 | 08:02 AM
gtr_rider's Avatar
192.168.1.1
Are you talking about the Steering rack or CV Joint?
Old Jan 12, 2006 | 08:18 AM
Cutler's Avatar
Just get a Raxle and call it a day , that will make life easy!
Old Jan 12, 2006 | 09:10 AM
shurik's Avatar
The outer front boot + clamp.
No I'm talking about the front outer boot and it's clamp. And that the grease is coming out from that boot sence the clamp doesn't hold it tight enough. I was looking to get those actual stock clamps not those fake OEM universal ones, but can't find them for cheap.
Old Jan 12, 2006 | 10:18 AM
86maxima96's Avatar
I Broke OT
what a mess! at least for me it was. oh, and what the best way to get that grease and ish off of the inside of the wheel? it is really caked on there...
Old Jan 12, 2006 | 02:11 PM
Tim96I30t's Avatar
I can see why you heard some noise, holy crap thats bad, when was the last time you looked under your car! Prevenative maintence is key, and alot cheaper, good luck on that one.
Old Jan 12, 2006 | 06:49 PM
MDeezy's Avatar
Seems like I get to joing the club of broken rack and pinion boots. Mine are broken on both sides. I unfortunately gotta ride it out till money is present to replace them.
nick has a great write up for replacing them, he used the zip tie technique also.
Old Jan 13, 2006 | 12:17 AM
Dave Holmes's Avatar
shurik,
Check with Advance Auto for their CV boot kit, and look at the clamps that come with it. I've used their CV boot kit and clamps 2+ years ago with no problems. They may be able to sell you just the clamps if you can find out the right size (or they can look it up). You'll need a special pair of crimpers to draw the clamp tight and crimp the raised nub together to keep it tight. They sell the crimpers (plier things) on their tool aisle for about $5. May be worth it if you have multiple ones to do. I can send you a pic of my clamps (installed) and the crimpers if you need to see what type I'm talking about. Just PM me your email if needed.
Hope this helps.
Dave
Old Jan 13, 2006 | 05:39 AM
nupe500's Avatar
Jedi Knight
Ok...not to be a smart *** or anything...but how exactly do you prevent boots from cracking?
BTW...I'm under my car at least once a week....don't ask...but i was there the week before and no issues....clearly not something that preventative maintenance could have done anything about.....
Old Jan 13, 2006 | 06:12 AM
camron21's Avatar
Yo my Max is making a lot of noise on the passenger side. When I turn it goes pop pop pa pop pop...... Will anything fall of this piece and do it need to be fixed ASAP
Old Jan 13, 2006 | 06:16 AM
nupe500's Avatar
Jedi Knight
Um....what do you think?...of course it needs to be fixed ASAP. No one can give you a finite time for which the axle or your particular issue can go without it being fixed.
On another note....my parts are in...time to go to work tomorrow.
Old Jan 13, 2006 | 08:09 AM
gtr_rider's Avatar
192.168.1.1
My broken boots turned into a rack and pinon replacement needed, new LCA's, and outer tierods....
Old Jan 13, 2006 | 08:42 AM
|Bijan|'s Avatar
UCF Lexus
I noticed the say my sh*t was taken to the body shop there's a small tear in the driver's side Rack & Pinion...
Gota tackle that weeeeeeeeeeeeeeeee!
Old Jan 13, 2006 | 09:35 AM
RockfordMax's Avatar
Back from the dead
The hell you have to look forward to
Lol.....need any help PM me
Old Jan 13, 2006 | 11:21 AM
nupe500's Avatar
Jedi Knight
Scratch that Kemosabi.....this car has been apart more times than I can count....not planning to strip a strut bolt/nut either......some of us have worked on our cars before....
Old Jan 13, 2006 | 11:27 AM
Back from the dead
oh thats low... real low...
Old Jan 13, 2006 | 02:28 PM
KsuMax's Avatar
Cheesing away...
that's not going to be fun
Old Jan 15, 2006 | 09:58 AM
shurik's Avatar
Originally Posted by Dave Holmes
shurik,
Hope this helps.
Dave
Pm sent Dave. My e-mail is shurik_velet@hotmail.com Please send me the pics would love to see them, cause I searched through that Auto Advance and can't still find them CV boot clamps that I need.
Old Jan 15, 2006 | 10:09 AM
Nismo3112's Avatar
Custom User Title
If I were you, I would add a cotter pin on top of the the ball joint nut!
Old Jan 15, 2006 | 10:16 AM
shurik's Avatar
shurik,
Hope this helps.
Dave
Pm sent Dave. My e-mail is shurik_velet@hotmail.com Please send me the pics would love to see them, cause I can't find that CV boot clamp that I need there. this is how it's suppose to look like
Old Jan 15, 2006 | 02:43 PM
Pic is on it's way...
Looks like the one above. Mine came in the Advance Auto CV boot kit. They may sell them seperately. If not, you could possibly check with an industrial bearing supply shop in your area.
Dave
Old Jan 15, 2006 | 03:01 PM
nupe500's Avatar
Jedi Knight
Done....pics to come soon...everything went well...from the strut mounts and strut bearings to the new tie rod boot as well as axle change and tranny drain and refill (Amsoil)...going to test drive.
Old Jan 15, 2006 | 05:24 PM
shurik's Avatar
Nice to hear that.
Nice to hear your proccess went though. I need to fix mine, it's just everytime I drive it's in my mind, and very very annoying that it's not done yet.
BTW Dave thanks a lot for the pic you sent me.
Old Jan 24, 2006 | 06:49 PM
nupe500's Avatar
Jedi Knight
Updated with Pics..
Ripped CV joint
New Axle:
Old tie rod boot
new tie rod boot
Worn beyond worn Strut mount:
Since replacing all the car definatley drives and handles much much better!
James92SE
142
Jan 2, 2024 09:23 AM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
