resurfacing slotted rotors?
As long as the rotor isn't at it's minimum thickness, it can be resurfaced.
The min. thickness should be stamped on the hub area or an edge someplace.
Cost should be the same as a blank, about 8 bucks.
Call and check local area shops and make sure they have the equipment (and, more importantly, the experience) to resurface slotted rotors. Slotted rotors can be easily damaged if they are not careful.
And make sure you get new pads as well. Don't run the old pads with the newly-turned rotors.
Originally Posted by theMax
After I had mine turned I cleaned out the slots with a dremel
Cleaning your slotted brakes with Dremel is a good idea but can be time consuming. I often go with an airhose and blow them brake dust away atleast once a week. No need to remove the brake rotors to get the back side.
Apr 16, 2020 05:15 AM
