Changed slave cylinder hose ,still not good
Old Feb 2, 2006 | 04:53 AM
hightuner's Avatar
Nissan maniaco conpulsif
Hi fellow entousiasts
96 Gxe Mt
Recently i feel the pain whith my clutch stuck on the floor
After looking a few post . I changed the the hose and bleed the line according to the procedure at motorvate.
after bleeding few time (aprox 7) its almost the same thing
I can change gears when the car is off
when the car is on i almost cant change the gear , it enter very hadly.. and i dont want to break someghing so i walk to work
the pedal feel like nothing appening at almost 2/3 of the travel
whats the next step ... slave cylinder ???
I still love my car btw
thanks you !
Old Feb 2, 2006 | 05:55 AM
cardana24's Avatar
Blown
yeah slave cylinder would be next, but make sure you have the clutch blead all the way. It takes me forever to bleed my clutch. I normally have to bleed it, then go drive around for a few minutes, and re-bleed. I do this 3-4 times before all the air is out. Goodluck.
Old Feb 2, 2006 | 06:29 AM
hightuner's Avatar
ill try that ... but i cant really change the gears ...
thx for the help tough
Old Feb 2, 2006 | 06:57 AM
cardana24's Avatar
Blown
I would bleed it some more it it were me. This is a dumb question, but are you keeping the clutch master cylinder full of fluid while you are bleeding?
Old Feb 2, 2006 | 07:17 AM
hightuner's Avatar
Yes we were adding some. dont worry i am ready to check all possibilitys
Ill definitively gonna try to bleed more tonight
Old Feb 2, 2006 | 07:18 AM
Requin6's Avatar
yeah i am also thinking you need to bleed it more. it did about 20 cylces just to be sure. takes a while, but it worked.
Old Feb 2, 2006 | 07:36 AM
hightuner's Avatar
should i always finish whit the upper bleeder ?
and is there any special procedure ?
at motorvate they say to LIFT the clutch pedal SLOWLY.
Should i get the vinyl hose like they mentioned ?
Old Feb 2, 2006 | 07:45 AM
cardana24's Avatar
Blown
I could never get my upper bleeder open, so that is probably why I had to bleed it more than once. Also I tried different ways of bleeding. I found that getting the guy in the engine bay to crack the bleeder as soon as I start pushing the pedal down slowly works the best for me. This is opposed to pumping it up then holding it to the floor while the guy cracks the valve open. As for the vinyl hose, I am guessing they tell you to put that on the bleeder so you dont shot DOT3 everywhere. Also if it is a clear hose you can see the air bubbles as they come out, so you will have a better idea as to when you are done.
Old Feb 2, 2006 | 07:48 AM
hightuner's Avatar
Thanks a lot .. i hope its only a mater of bleeding
Old Feb 2, 2006 | 08:28 AM
hightuner's Avatar
Off topic question
why nissan made 4 loop whith the piping ?
Old Feb 2, 2006 | 08:33 AM
Jeff92se's Avatar
I'm needing a caw
Reason for the line replacement? Leak? If the slave cylinder is leaking, that might cause the mushy clutch pedal. But yes, you might have to bleed the block that's inbetween the master and slave clyinder
Old Feb 2, 2006 | 09:48 AM
hightuner's Avatar
the reason .. was my pedal was to the floor. And i cant change gear
The oil was almost all gone in the reservoir
the hose was covered whith oil.
We inspect the slave and it looks ok . It pull the fork but not enough
I can drive it like that in 2 . stop and go in 2. but i cant (almost) shift
It enter very hardly in other gear .. i dont want to break somthing
How do i bleed the connection block
Is it the part 30655+B ?
Old Feb 2, 2006 | 09:59 AM
cardana24's Avatar
Blown
its the valve on the slave cylinder its self...its looks like the one that is on top of the strut tower
Old Feb 2, 2006 | 10:16 AM
hightuner's Avatar
yhea that what i was doing
the upper and lower bleeder just like motovate show
HUmmmm
I was just wondering what jeff92 mean by bleed the block
Old Feb 2, 2006 | 10:47 AM
El_Presidente
Sometimes a slave cylinder can suck in air through a bad seal, but it might not leak fluid. I've seen that on some RWD cars, but not sure if the maxima is the same. Maybe try changing the slave cylinder?
Is there any way to check the master cylinder also? Could be that the seal is bad, and fluid goes around the piston instead of being pressurized.
Old Feb 2, 2006 | 10:55 AM
Jeff92se's Avatar
I'm needing a caw
Scopium. Please explain why El Presidente has the same exact reply as you and the same exact IP address. But yet have different cars and different locations. Thanks. -admin-
Old Feb 3, 2006 | 08:11 AM
Jeff92se's Avatar
I'm needing a caw
Old Feb 6, 2006 | 06:32 PM
hightuner's Avatar
It work finally !!!
Thanks a lot
I really appreciate
Edit : next .. hood strut .. Greddy sp2 lss y+test pipe
Old Feb 7, 2006 | 11:06 AM
Jeff92se's Avatar
I'm needing a caw
Old Feb 7, 2006 | 11:15 AM
cardana24's Avatar
Blown
I assume scopium has been banned?
*on topic* congrats one getting your clutch problem taken care of.
Old Feb 28, 2006 | 10:06 AM
Jeff92se's Avatar
I'm needing a caw
>>>>>>>>>>>>>>>>>>>>>>> And please advise why you left a trader rating for El Presidente when you are both people. Happen to sell something to yourself?
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
vanebecker
Aug 17, 2015 08:24 PM
RealityCheck
Aug 5, 2015 06:18 AM
