hmmm is the stealership supposed to charge to fix a tsb???
Old Feb 4, 2006 | 02:11 PM
maxpwr2k1's Avatar
i have an 01 and pulled a P0420...thats the 3 way catalyst, but there is a tsb that says the 02 sensor does not need to be replaced but that the ECU needs a reprogram. I made sure to check and see if it applies to my particular model and it does...
i went to the dealer and they wanna charge me 200 dollars to get the CEL off...there is nothing wrong with the car so i dont see as to why i should throw away 200 dollars for no reason...
arent they supposed to take care of TSB at no charge??? im not quite sure but im just under that impression. any opinions
thanks
-dave
Old Feb 4, 2006 | 02:15 PM
MaximaZero's Avatar
Needs non-Maxima Friends
Only if you're still under warranty.
Old Feb 4, 2006 | 02:21 PM
maxpwr2k1's Avatar
arent TSB's covered for 8 yrs/80k miles regardless??
Old Feb 4, 2006 | 03:41 PM
scmaxima2k's Avatar
Nope... TSBs are not like recalls. They will only pay for it if you experience the problem while under warranty. Theres no special exception for TSB issues.
Old Feb 7, 2006 | 08:26 AM
D Love's Avatar
Isn't there an 8yr/80k emissions warranty?
Old Feb 7, 2006 | 09:03 AM
NismoMax80's Avatar
SuPeRmOd
Technical
Service
Bulletin
Where do you get FREE out of that? If it was a Recall, it would be called Recall not TSB. Only purpose is to provide technicians a resourse ofr know possible problems with solutions. When your warranty expires, it expires.
They will always charge you for computer diagnosis. I'm sure your Gen has a Sticky on how to remove the light.
Old Feb 7, 2006 | 10:26 AM
Larrio's Avatar
The Definitive AE Master
The dianostic fee at the dealer should only cost $85 dollars (at least that is the standard rate around here). The fee is applied towards your service total if you decide to do the service at the dealership
Pnjboyzz
Nov 16, 2015 12:27 PM
AboveDaCloudz
Oct 8, 2015 11:25 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
