HLSD or Open Diff? Pics inside...
Old Mar 12, 2006 | 02:37 PM
TurboS13Hatch's Avatar
I can't tell from the pic... I looked up the VIN code in FAST, but couldn't get a definate answer. Can any of you guys tell from look at these pics? Maybe some "trick" piece that would differentiate the two? One of my customers purchased this swap off of Ebay, without asking if it was HLSD or not..
Travis
Old Mar 12, 2006 | 02:40 PM
Matt93SE's Avatar
STFU n00b!
post VIN.
or call you local dealer and ask them to stick the vin into their computers and see what it comes up with.
Old Mar 12, 2006 | 02:44 PM
JN1DA31D03T504748
2003 Maxima
The trim that it gave me on FAST was "SES"
Old Mar 12, 2006 | 02:51 PM
SR20DEN's Avatar
VQ Wizard
The HLSD has no spider shaft.
Old Mar 12, 2006 | 03:04 PM
I wish I had the trans here, so I could look at it up close. Unfortunately, these are the only pics that I have for now..
Travis
Old Mar 13, 2006 | 07:49 PM
Matt93SE's Avatar
STFU n00b!
it's a non-LSD according to FAST.
the LSD part code for the diff is 38411Z.. (38411-96E01)
FAST shows a 38421Y part code for your VIN. (38421-97E00)
Old Mar 13, 2006 | 09:41 PM
I have FAST... how did you determine the part number using the VIN code?
Travis
Old Mar 13, 2006 | 09:45 PM
Which brings me to the next question... can the HLSD bellhousing side of the trans case bolt up to the non-lsd trans?.. If you were to put the helical diff in the trans?
Old Mar 14, 2006 | 04:18 AM
Matt93SE's Avatar
STFU n00b!
punch in the VIN on the car into FAST and then get the part number for the diff that pops up when you search by description (or by pics)..
then clear out all the data and do it again just using the chassis code... when you get to the diff, it'll pop up with a box asking if you're looking for auto/manual/LSD/no LSD and production date stuff.
the LSD one is noted in the part description, and yours is not.
as for if the bellhousings fit, look it up in FAST yet again. if the part numbers are same for the LSD and non LSD bellhousings, then you're good.
Old Mar 14, 2006 | 03:30 PM
Thanks Matt... I'm still trying to learn how to navigate around the FAST system.. It looks as thought the part numbers are the same for the bellhousings.. Also, the axles are the same..which means that the HLSD should fit in.. Just swap the ring gear over, and bearings.. then reshim accordingly. I'll let you guys know how it goes.. Thanks again for the help.
Travis
Old Mar 14, 2006 | 03:48 PM
SR20DEN's Avatar
VQ Wizard
I usually just even swap the differentials when they're the same ratios. Otherwise I just swap the ring gear if the ratios are different.
Old Mar 14, 2006 | 08:41 PM
Now.. I just have to find a diff.. Brand new, they aren't very cheap.
Old Mar 15, 2006 | 09:00 PM
Hoooper
wheres the spider shaft? i just picked up a 6spd of my own and im pretty interested. i got this number off a plate on the side: JN1DA31D4. i guess thats part of the vin, not sure where the rest went
Old Mar 15, 2006 | 09:02 PM
Puppetmaster's Avatar
Maybe try looking through the FSM?
Old Mar 15, 2006 | 09:13 PM
Hoooper
if i had an fsm...
i found the rest of the VIN, JN1DA31D42T449493. can anybody possibly look this up for me?
Old Mar 16, 2006 | 12:24 AM
You have an open diff... part code 38421-97E00 (38421Y)
Old Mar 16, 2006 | 02:32 PM
Hoooper
perfect
Old Mar 16, 2006 | 04:04 PM
HotshotVQ35's Avatar
is this for that the b13 swap u been talkin about on sr20
Old Mar 16, 2006 | 04:36 PM
Hoooper
what? im not sure what you said, but its for a 6spd swap in my A33B.
Old Mar 16, 2006 | 05:18 PM
This one is actually going into a B15.. which will be featured in SCC Mag this summer, in the Hybrid How-To section.
The one that's going on the 9500rpm SR20VE turbo project is coming off of a QR25DE, with a custom adaptor/flywheel, etc..
Travis
Old Mar 16, 2006 | 07:18 PM
Zack342's Avatar
Stop stealing our engine swaps.
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
