Do slotted or cross drilled rotors give me better braking power? Or is it just for
I'm sure Avalon Racing might debate it but anyhoo
http://www.shotimes.com/brakes/part2.html
While we are at it. Brake fluid differences:
http://www.shotimes.com/brakes/part5.html
Brake rotor break-in and care:
http://www.shotimes.com/brakes/part1.html
Brake pad survey: should be coupled w/ Bill's excellent adventure w/ brakes
http://www.shotimes.com/SHO4brakesurvey.html
Originally posted by Screaminfast
Do you guys think that the Stillen X drilled rotors are a bad set of rotors? I just bought them, now I read this, and I feel disappointed. Any suggestions?
Originally posted by deezo
I am sorry to say I own a set of Stillen's cross-drilled rotors but they are very good and have great stopping power as opposed to stock.
I got slotted rotors for my Acura 3.2 because I needed a new rotor and the performance slotted rotor costs wayyy cheaper than stock. They looks hot too.
As for the pad, they are better than stock and cheaper also.
As for the Koni, they are cheaper than stock and perform wayyy better. I needed them replaced anyways, so I just bought them thinking that I got a great deal compare to getting stock $hitz.
ok this should be well known by now......
X-drilled rotors are only used in the highest eschlons of racing like on a porsche GT-1 and cars of the same class
X-drilled rotors have a higher tendancy to crack, more than anything..... they were made to help rid the gasses that built up from the specialized pads that the race cars were using... because of the gasses the pads wouldnt come into contact with the rotors, so they x-drilled them to help rid the gas....
Slotted rotors will work more than efficient with street setup, if you watch the Speedvision Touring car and Grand touring car you will see that 99.9% in the touring series use the slotted rotors, and id say that 10% if that in the Grand touring use the x-drilled.
Slotted is one of the ways to go, but i dont think you will ever use your brakes enough to fully utilize their potential.
This has been my helpful post of the day, i am now resuming Jerk Mode - thank you ... muwhahhaha
Wow... you can give info in kind manner... no **it..
unlike most times when you are telling people to **ck off ..
hehe thanks...
hehe thanks...
hehe thanks...
Originally posted by Chris91SE
the true stopping power is coming more from your pads then the rotors per say... the x-drilling is there to keep the rotors cool under heavy breaking (ie race applications) i kinda wish i went slotted but i'm happy none the less...
mm: I went with aftermarket pads and rotors.
Neel, how's the wife and kids?
So, how many have had any cracking problems with their X-drilled rotors?
Originally posted by Jeff92se
You wanted info, I got you info. I coulda did it verbatim but this was faster :smile
You doubting my knowledge Kev?
Say what? Nah, I don't doubt your knowledge... except for the cat food breath and bunny beans statements.
Originally posted by Y2KevSE
Any other input?
Any other input?
Having X-drilled or Slotted rotors will improve your braking in the rain when the rotors are wet.
This would be because when you brake with wet rotors that water is going to boil and create a pocket of gas under the pad, if you have x-drilled/slotted rotors that gas will escape, otherwise you will get the famous "oh crap I just drove through a puddle and my brakes don't work" effect
Good....Brakes are good....Wait....Stopping faster....I just was rear ended twice a week ago....Uh Oh....stopping faster?!?!?
I hope that once I put these upgraded brake equip (X drilled rotors, new pads, SS lines, etc) that I dont stop so quickly that I get in more rear end accidents...hehe
Note Screaminfast:
Break in the rotors the way Stillen says to in the instuctions. The rotors will make grinding noises until the gold colored plating wheres off. The main thing is to drive under 35mph the first day and don't brake hard when you are braking them in.
I took my car to an empty lot and drove around until the grinding sound diminished a bit. While doing this, I let the rotors cool off a bit buy taking a breaks with the break-in process. Then, I drove around running erands and the rotors smoothed out perfectly.
I don't think the drilled rotors make too much of a difference. I went from stock brakes to 300ZX TT brakes with stock 300Z pads and stock 300Z rotors. This obviously made a huge difference in braking. I then went to Axis pads, which also made a large difference. I recently went with a full set of X drilled Brembo rotors front and rear. There is a little difference, but not a whole lot. And a lot of that difference can be accounted for by my old rotors being worn thinner. These new rotors are considerably thicker than my old worn ones and so the pedal feel is better. The pads feel like they bite more, but it's probably just psychological.
You are going to find yourself stopping hard sometime to listen to the rotors hum.
Note Screaminfast:
Note Screaminfast:
lowpost99
Oct 26, 2025 06:53 PM
