Need help now!
Old Jun 17, 2001 | 04:34 PM
A-Ron Max's Avatar
Since yesterday my check engine light came on. No problems driving but I wanted to find out what the problem was so i would know whether or not to take it to the dealership to get looked at. I use the ECU diagnostic from this site, and i got code 0303 ~~~~> Front Left Heated O2 sensor. Not sure what this means, but now when i try to start up the car it will start, but then just die if i don't give it any gas. Did i do anything wrong? because this wasn't happening before i ran the diagnostic, any help would be appreicated or else I'll just take it in to the dealer tomorow morning.
Old Jun 17, 2001 | 07:20 PM
A-Ron Max's Avatar
Ok someone must know something to help me out
Old Jun 17, 2001 | 09:22 PM
justmax's Avatar
you will find your answer...
in the 4th gen forum, near the top... it's a sticky post re: ECU codes.
Old Jun 18, 2001 | 11:20 AM
emax02's Avatar
It is strange that your car now stalls. I whould look and make sure you placed the screw back in it's proper position on the ECU. You may still have it in diagnostic mode and this may explain why your car now stalls. The o2 sensor on your car should be replaced because it does help control your air/fuel ratio and it also helpes with emissions, a new o2 sensor from nissan will cost you $85 for the part + leibor.
