View Poll Results: Oil Cooler Worth it?
Yes, Definitely!
26.67%
No, It was the worst purchase ever!
0%
I dont have one, but I'm interested.
60.00%
I dont have one, and I'm a post whore.
13.33%
Voters: 15. You may not vote on this poll
Old Jun 18, 2001 | 06:24 AM
Screaminfast's Avatar
Let me know what you think. I'm getting a S/C and I wonder if I need it. Usually, the hottest my oil has ever gotten is 175 F. Normally, it doesn't run any hotter than 150.
Old Jun 18, 2001 | 08:23 AM
delio's Avatar
Hey Mike
I just installed mine this weekend. If you want specifics then IM me. I would not install the SC without it. I am bone stock still performance wise and I noticed a difference (no not 10whp) in the behavior of the car with the cooler. I did not expect to feel anything, but most definitely did, the car just seemed to feel alot happier revving out to 5k+. Even my girl noticed that the car just seemed to be alot smoother and stuff. Definite must have if your boosting IMHO.
Del
Old Jun 18, 2001 | 08:30 AM
Roger that Delio....Which one did you get and about how much? I'll look into the setup.
Thanks.
Old Jun 18, 2001 | 09:18 AM
MardiGrasMax's Avatar
Thanks.
Yea Ive been pondering this in my future too...
Where did you guys tap your oil temp/pressure gauges into?
Old Jun 18, 2001 | 09:30 AM
I had a T-fitting put into where my stock Oil Pressure Sender is, and I connected the Oil Pressure sender and the Oil Temp sender there. I had it done at a shop.
Old Jun 18, 2001 | 10:08 AM
delio's Avatar
Mike
I used the Stillen setup... a little pricey and the instructions were an absolute disaster...good thing it doesn't take much brain power to figure out.
Matt... no guages yet...soon... Waiting to see what happens to a potential AFC purchase, then I can decide where/what I am going to mount.
Del
Old Jun 18, 2001 | 08:29 PM
Come on guys....I need some more comments....
Old Jun 18, 2001 | 10:49 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
hey
im working on one, i dont think the Stillen one is worth the money and i cant get it cause my intercooler is where the oil cooler goes. Im gonna mount mine in the right foglight hole at an angle. Basically you need a sandwich adapter, and get some lines and fittings and you got yourself an oil cooler...
Old Jun 18, 2001 | 11:23 PM
Kenneth's Avatar
OG :)
Just use synthetic.
Old Jun 19, 2001 | 01:04 AM
got rice?'s Avatar
Originally posted by Kenneth
Just use synthetic.
Use syn & and oil cooler
Cooler oil will prolong your bottom end even if the temp drop is only 10-12 deg. Cooler oil = happy engine.
Old Jun 19, 2001 | 01:24 AM
geomax's Avatar
were does the oil cooler get placed
Old Jun 19, 2001 | 06:36 AM
Just use synthetic.
I use Synthetic now. I want to have a custom Front mount Intercooler for my S/C eventually, will that conflict with the Oil cooler?
Old Jun 19, 2001 | 01:14 PM
got rice?'s Avatar
anywhere you want. It can be mounted horizontally or vertically. The optimal place is in front of the radiator but it can be mounted elsewhere.
Even if it's stuck behind an intercooler, it'll still act as a heat exchanger. It won't be as effective as if it were place in direct cool air but it'll still cool the oil.
Old Jun 19, 2001 | 02:41 PM
OgreDave's Avatar
Hmmm, really. I need to smack delio. He told me his bolted into that middle pole down infront of your AC condenser. My tranny cooler is partially blocking that. If I can mount it anywhere, thatd be more of a plus
Old Jun 19, 2001 | 04:54 PM
delio's Avatar
Dave...
The Stillen kit uses the Center M8 bolt from the rod coming down right in the center of the car and goes to the left of the car...towards the driver side. Those people who are saying to mount it anywhere are talking about custom setups or modifying the Stillen kit to their own needs. Want me to fax you the install instructions?
Del
Old Jun 19, 2001 | 10:19 PM
OgreDave's Avatar
Re: Dave...
Del
What, you mean i cant smack you anyways?!?!?!?
Is it just the bolt, or?? Cuz if its just the bolt, i can fit it in standard location.
Old Jun 20, 2001 | 12:14 AM
Turbo95Max's Avatar
Delio
i want some info, want to get this oil cooler project taken care of and figure out how im gonna mount it. Id appreciate any info and/or pics too....come to Cali and we can install that new toy of yours.
Old Jun 20, 2001 | 05:22 AM
Originally posted by Turbo95Max
Delio
hahaha....he's supposed to come here to help me install mine...hehe
BTW, delio, you think the Stillen Setup is gonna conflict with your Intercooler? U doin a FMIC? (Front Mount Intercooler)
Old Jun 20, 2001 | 12:12 PM
Turbo95Max's Avatar
screaminfast, im pretty sure the Stillen cooler would get in the way of any intercoooler. the Stillen one mounts smack in the middle so it would interfere with any type front mount setup i think. thats why im gonna mount mine in the right foglight hole...good luck
Old Jun 20, 2001 | 02:09 PM
OgreDave's Avatar
Hes puttin the intercooler where the stock battery is, i think.
Old Jun 20, 2001 | 03:04 PM
delio's Avatar
Bad Dave
You tell people where the IC is mounted? Bad bad bad...
Anyways Dave, You need that bolt...you actually unscreww it and slide the OC between the rod and the bolt then screw it back in, but you don't need any room to the passengers side of it other than to run the hoses back to the oil filter adapter, so your front grill are to the pass side of the Nissan Emblem on your grill is clear. I think if you use the nissan emblem as your dividing line you will see it better. If you can see the "M8" bolt at the bottom, in the opening of the lower air damn, right below the emblem, then you are straight.
Screamin... The OC will definitely interfer with any intercooler setup unless you go with a custom front mount, or with a setup kinda like I am doing. I won't go into too much detail about my own setup. If you want info I will give you my # and we can talk on the phone.
Turbo...what you need man? I can fax you the install docs, and send you pics soon as I scan them. Ni digicam for me right now, spent a wad on my new "toy" hahahaha.
BTW Got a big box in the mail today, wonder whatever that could be.
Later,
Del
Old Jun 20, 2001 | 06:57 PM
OgreDave's Avatar
Re: Bad Dave
Later,
Del
Would you rather i provide pics?!?!?! You already lectured me about it.. I dunno wtf that box is.. hope u dont have to drive around like me for hours n hours.
Thanks for the description of the oil cooler.. ill go check again n see..
Old Jun 20, 2001 | 08:30 PM
I'll IM you next time you're on Del....peace
Old Jun 28, 2001 | 12:59 PM
Heres a new idea!!!?!?
Put the oil cooler behind the grille with the Nissan Hamburger Emblem???
Good, huh?
(Don't mind me, I'm in one of those moods, I dont have to work tomorrow)
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
Forge277
Jun 13, 2016 09:26 PM
05RLS2
Apr 14, 2016 11:49 AM
