electrical question
Old Jun 18, 2001 | 08:37 AM
Roman-dude's Avatar
I tilted the sunroof open and now it won't close. When I push the switch "close" nothing happens (not even a sound), when I hit it "open" I can hear the motor running (it does not tilt the roof any higher since it's already open). I called Nissan and they suggested that the switch may have gone bad (I had a liitle flood too on that day). Or can it be the motor? which one can it be?
thanks
Roman
additionally...
It (flood) was not too big, but the switch was wet. It was wet before too (during the earlier incidents). I have now noticed that the rubber that goes around the glass has about a 1/10 of an inch gap where it meets, so I think that's where it leaks (should I use some silicone there??). The water has actually manifested itself inside dripping on the rear right seat (where the seat belt is) and the sunshade was wet as well. After I started driving it (probably moved around and) started to drip from where the ceiling meets the door on the front passanger side and from the switch itself. But nothing dripped from the left side (probably because the car was slightly tilted to the right while it was parked overnight during the rain).
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
